SEE MY OTHER INSTRUCTABLES FOR INSTRUCTIONS ON HOW TO CARVE A SEALING STAMP
Remove these ads by
Signing UpStep 1Preparation
FABRIC HOT GLUE: It looks like hot glue, except it's white. the stuff I use is called "fabristick" or something.
DYE: Any kind of colorant can be used. I prefer RIT dye (very cheep).
BEE'S WAX: You only need a tiny bit. If you don't have this, paraffin works OK.
MORTAR AND PESTLE: You will need it for grinding the RIT dye into fine dust.
A CANDLE SETUP: It is featured in the picture below. Looks like a candle under a metal tripod.
ALUMINUM DISH (OR EQUIVALENT): Use one that is small enough to be used in the candle setup.
WORK PAPER: Something that you won't mind getting wax on. your going to work on top of it.
BEGIN!
I'd like to commend you for how thorough your 'ible was.
I have a question though; is bee's wax a requisite or would normal candle wax work? I see you said that paraffin is acceptable too; is paraffin synonymous with normal candle wax?
Thanks!
Regular candle wax and paraffin are typically the same thing. However: regular candles might not be entirely paraffin, they might also contain a percentage of beeswax. Which is totally fine :)
Good luck!
-Calvin
I'm planning on creating mailable seals, so I'm curious to hear from someone who's got more experience on this stuff.
You can't add a wick, I've tried :(
The wick doesn't stay lit because there is not enough wax in this mixture fuel a flame. The only reason you add wax is to disrupt the stringy qualities of the hotglue.
Any source for the pigment/dyes?
It can be purchased at most craft stores, and is staple in any fabric stores.
I believe Wall*Mart stocks it, as well.
This instructable is pretty old... no wonder you had trouble finding it! It's also not quite as well done as my newer ones...
http://www.instructables.com/id/Homemade-wax-seals-part-1/
Good luck and tell me how it goes!
-Nepheron
-Nepheron
