3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Homemade Sealing Wax - EASY! PICTURES!
Step 11Removing Foil and Finishing Touches
After it is cooled, do not try to remove the foil. Put it into the freezer to make the wax super cold then remove the foil. If any foil remains stuck to the wax, use an X-Acto knife to cut it away.
I also melted the bottom of the wax stick and impressed my wax seal onto it...
This wax is different to use than other varieties. Mainly it differs because it has no wick. To use this wax there are 2 ways:
1: Using a butane torch, heat up the end of the wax stick until it melts. Drip the blob of melted wax onto the object you are sealing and stamp it with you seal.
2: Cut the amount of wax you want to make a seal with and place it in a spoon. Put the spoon above a small open flame (i.e. candle flame) until the wax in the spoon melts. Drip the wax in the spoon onto the document you are going to seal and stamp it with you seal.
Have fun and be safe!
6 comments
Aug 27, 2011. 8:54 PMjcoronel1 says:
Great tutorial. Easy to understand and really helped me make it my own. Lots of room for self editing! Also I used a small ceramic bowl to mix it all up, it took a long longer than i think it should have so i am assuming it is alot easier with a metal one?
Jul 5, 2011. 11:50 PMcrimsonhalo says:
Does the colour transfer to any other surface once the mix has been applied as a seal? Or is the glue and wax sufficient to keep the dye contained?
I'm planning on creating mailable seals, so I'm curious to hear from someone who's got more experience on this stuff.
Sep 7, 2010. 5:41 PMOryctolagus habilis says:
Wow: what a great recipe & you can do it in any color RIT makes! I'm sure you could use standard candle-casting techniques to add a wick to the stick if you wanted to.
Sep 10, 2010. 2:09 PMOryctolagus habilis says:
Aha! Thank you for letting me know that, since I'm definitely going to make this & now know not to bother trying to add a wick.
Feb 14, 2009. 5:56 PMMetalcaster14 says:
good instructable!
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
316
Author:nepheron(MakerWeekend)
I have an awesome blog @ www.makerweekend.com Im Calvin Drews, and I love to learn, experiment, invent, create, repair, and generally just do things myself. A sort of modern jack of all trades, mast...
more »
