Step 4The Method - Body
2. Cut two blocks of wood to a suitable size that they will support the mesh 3 inches off the floor, this is to hold the blasting piece out of the grit collecting on the floor.
3. Screw the mesh to the wooden blocks using wood screws and washers to form a solid base that stands freely in the bottom of the tub.
4. Using the drill and jig/fret saw as before, cut a hole approximately 4 inches in diametre in the centre of one side, reasonably near to the top. I suggest using a round object such as a grease tin to mark this out most easily. If you are unsure, start with a smaller hole, I have big hands and wear thick gloves so you might be able to get away with a smaller hole. The smaller the hole, the less grit will leak out. Round the edges of the hole with the file.
Add Comment
