Introduction: Homemade Snowmobile
Homemade snowmobile. Collapsible. Length 1,55m disassembled. The maximum speed of 45 km / h. Removing the steering wheel and skis 1 minute.
Step 1:
4 roller diameter of 130mm. Mounted on the bearing diameter of 52mm. To reduce the weight of the spring is not installed. Led Star 40-46. Circuit 520.
moving the drive and driven roller
Step 2:
Centrifugal clutch made of the car's brakes. The brake drum bearing 2 installed. On the motor shaft sleeve dresses with defined blocks of the same car. Pads compressed springs. When you reach 2000-2200 rpm pads to uncoil and begin to rotate the drum from the vehicle.
Step 3:
188F Engine 380cc. 4 cycles. Manual start. Tank 6.5 liters. On the installed motor centrifugal clutch. Star on the engine 11.
Step 4:
Drive by snowmobile. Width 220 or 380mm. I collected with both options. Much difference in patency noticed. The length of 2 meters.
Step 5:
Ski by snowmobile. Plastic pad and a metal frame. Shaft diameter 25mm. Ski has a swing on a hinge. I recommend lydu drop slightly below 50 mm. You can set a spring. Removal and steering skis going 1 loosening the bolt. Therefore, it is fast enough.
Step 6:
The frame is made of metal profile 20 * 20 * 2 mm and 15 * 15 * 1.5mm (top). To reduce the weight of the spring is not installed. they are not required for snow. The frame must withstand jumping, so sledat reinforcing plate. Frame length 1.55 meters. Front and rear moving star. Front chain tensioner. Rear drive for tension
Step 7:
All videos.
The technique is very interesting. Required management skills motorcycle or bicycle. The speed of up to 45km / h.
