Spin Art Machines have been around for a while and I have seen them at craft shows for years. You could buy a Spin Art machine for anywhere from $12 ...
Using a dremel or other similar tool, slice existing fan blades from unit. Discard blades into trash. It's ok if you have a little excess "stump" from...
Using at least 4 drywall screws, attach cardboard base to fan. Keep in mind you may have to use trial / error here. I noticed that in some spots, I co...
After I was sure the cardboard was firmly attached, I let the fan run on the highest setting to make sure the cardboard did not spin off. If you feel ...
PDF Downloads As a Pro member, you will gain access to download any Instructable in the PDF format.
You also have the ability to customize your PDF download.
