3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Homemade Sport Utility Bike (SUB)
Step 4Frame Support
Frame Support
We need to prevent the swing arm from flopping over and make the bike ridable. I bought a 3 foot section of steel tubing and made a support bar that links between the swing arm (where the spring/damper normally would connect) and the kick stand mount.
I drilled the holes.... With a Dremel. Even that angled hole. Terrible, I know, but I made due with what I had.
This support bar is held at the kickstand mount with a half inch grade 8 smooth shank bolt. I had a grade 5 full threaded bolt at one time - it failed (bent). It was my fault, I didn't take the time to do the engineering (which I was capable of) and I would have easily seen that it was not sufficient.
6 comments
Sep 21, 2009. 6:08 AMHycro says:
I wonder if there were a way to attach to the seat post bolt...I can think of a way, but it requires a piece of flat bar (Or is it called flat stock??) welded into the end of the tube that will attach to the seat post bolt, that is also cut in such a way that the bar rests against the seat tube, and the bolt just keeps it from moving around, but most of the pressure is on the frame...I don't know if what I suggested would even work, if there were welds, let alone if you just used all bolts...but if it did work, it could have the potential to be stronger than attaching to the kickstand mounting bracket...since on some cheaper model bikes, the kickstand mounting bracket welds are VERY cheap...
May 18, 2007. 11:21 PMadamlorenz says:
any way to see more detail pictures of the tubing and how you connected them to the two sections... i'm at the point of doing this and i'm in need of some visuals before i start at it... thanks!
Aug 20, 2007. 7:48 AMcamp6ell says:
i too would like to see a pic of where the support rod bolts to the main frame, when you do get back to your bike. thanks.
Nov 20, 2008. 10:11 AMctsp415 says:
Nice idea, have you figured out a rack system similar to the xtracycle for carrying loads. Otherwise it's just a very cool extra long bike.
Jan 11, 2011. 6:24 PMjoshfromga says:
i just finished a longbike of my own. my rack is an old wire-frame dvd rack. pics are here.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
324
Author:trebuchet03
I'm an Engineer in San Francisco. Mass producer. Former Intern. Rapid Prototyper. Sometimes, I post Instructables. My Favorite number: 42 By profession - I am an energy engineer. I count electrons p...
more »
