3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Homemade Spot Welder
Anyone can build this simple to use light duty spot welder. I found all the parts I needed in my shop. I looked at some other plans on the Internet but they all seemed to require something I didn't already have.
Step 1The transformer (core)
I had three MOTs (Microwave Oven Transformers) collecting dust in a box with a bunch of adapters and transformers. The one was exceptional for the fact that the primary and secondary were separated by a shunt. Placed on it's base the secondary was on top and the primary on the bottom (pictured).
I used a pipe cutting blade (hacksaw blade) on a reciprocating saw to cut the secondary off the transformer core. Near the end of the cut I had to use extreme caution as I did not want to damage the primary coil. The primary and secondary can be identified by the number of turns and the gauge of wire. The secondary has many thousands of turns and uses hair thin wire. The primary is more like 18 gauge.
Once the secondary coil was cut away I used a short metal bar and a hammer to pound the trapped portion from the core. It was wedged in there pretty good. I cleaned out everything except the shunt and the primary.
131 comments
1-40 of 131next »
Dec 22, 2011. 5:33 PMxXxFelipexD says:
it works by giving short circuit? because I think it would be necessary to place a resistor
My multimeter is saying is that my primary resistance of 3.5Ohm
I think it strange
Nov 29, 2011. 4:17 AMthrobscottle says:
I would like to say thank you for your instructable - yours is one of the designs I looked at before coming up with my version, and gave me some inspiration!
Mar 14, 2011. 9:03 PMnarpas says:
So is there any electrical danger from the actual arms? Or is the voltage not high enough to be a problem. Is it just a danger from the parts that are running at 110 V?
Nov 23, 2011. 6:47 PMwiseboy says:
Current (less than 1 Amp.) may kill . Be sure to ground and NEVER touch any parts when experimenting ...
Dry air and floor are vital as electricity resistant gloves ...
Electricity is no game ...
Be sure you don't bet your life !
Jul 11, 2011. 6:40 PMmagiccowy says:
Having a problem with mine. I have two transformers with the input in parallel and the output in series. I get a great spark between the wires while testing but when i joined it all to my welder the secondary wires get really hot and it doesn't make the weld. I used non-copper contact screws by the way.
Any help would be appreciated
Jul 13, 2011. 12:52 AMmagiccowy says:
I got the Amperage over Voltage thing sorry that was badly said. The circuitry is all fine and me and my dad came to the same conclusion about the tips.
Thanks for all the help anyway I'll try and comment a picture when its working
Oct 2, 2011. 6:29 PMswitch62 says:
You might have the secondaries  (output) of your transformers connected out of phase.  You may need to swap the wires on one side of one of your transformers.
The phase of a winding depends on which direction it is wound, clockwise or anticlockwise, in relation with the other windings.  Your  transformers should be setup like the diagram below.  The dots on the terminals represent the phase polarity, like positive on a battery.  If the primary is wired the opposite way the phase flips on the secondary
If one of the secondaries is wired the other way or it's phase is flipped then you will get little or no voltage from your welder and the secondaries will get hot. The 2 secondaries are fighting each other instead of helping (adding) each other.
If you connect one of your secondaries the other way your welder should work. But as jds said more current is better than more voltage.  Only time you may need more voltage is if you have a high resistance metal or joint.
Phase is also important for parallel connection as well.  Even more so beacuse as soon as you apply power the secondaries are "fighting" and you can blow a fuse or a winding.
Oct 2, 2011. 10:19 PMmagiccowy says:
Mine is set up as your first diagram shows. I really have to talk to my electrotechnology teacher about finding the phase better.
The way I found it was connect it one way, see how powerful the spark was, then switch and compare them. Connected one way I only got a small spark, the other way there was a bright glow, akin to a arc from an arc welder. I assumed this is because the power was adding on as opposed to cancelling each other out. Would I be right in assuming this?
Oct 3, 2011. 7:58 AMswitch62 says:
I would say bigger spark would mean that you have the secondaries wired in phase.
The easiest way to check phase is using an oscilliscope so you can see both AC waveforms at the same time.  Wire the mains to the primaries in parallel and then use a dual trace scope to connect to the secondary windings.  The windings should not be connected together.  If the waveforms are in phase, the peaks and troughs will happen at the same time.  If out of phase the peaks will line up with the troughs.  Once in phase the positive of each probe will be the dot.
But not everyone has a scope.
The other way would be to measure wire up the secondaries in series.  Then measure the voltages across each secondary, V1 and V2.  Then measure the total voltage VT.  If VT= V1 plus V2 then in phase.  If not equal, probably close to 0VAC, they are out of phase, flip the connections on one secondary.  Use an AC meter for the voltage measurement.  You also might need a resistor across the secondaries, say 100 ohm at 5 Watt for this situation, the resistor may get hot.
Note: this only checks the phase relationship between the secondaries.  It will not check the phase relationship between primary and secondary (dot convention) of each transformer.  To do that you need a different type of setup for safety.
Oct 4, 2011. 8:35 PMmagiccowy says:
Thanks for your help, I'll try get back to you once school starts as i may have access to an oscilloscope. Fingers crossed =).
Aug 5, 2011. 3:00 PMaburbano becerra says:
Muy bueno gracias...
Jul 27, 2011. 11:31 PMthe.rollie says:
those are the only two reasonings i ever needed to build something.... wanted one, and needed one for some miniscule task/problem
May 15, 2011. 10:39 PMelectroboy1337 says:
Where can I get some 4 Gauge wire? Will this do? http://dicksmith.co.nz/product/W1230/4-gauge-power-wire-transparent-red
Jan 14, 2011. 11:10 AMustech says:
HELLO AL
CAN WE USE IT AS BATTERY TAB WELDER(BATTREY REBUILDING FOR LI ION, NICAD ETC
Dec 7, 2010. 7:44 PMharlyquin says:
I'm sure I'm restating general knowledge here; if you can get wire for the secondary new, it will make winding much easier. Copper work hardens and becomes ridged and brittle if any deformation occurs. If you find 10 g wire difficult to wind, it will only get harder if you try to redo it!
Jun 25, 2010. 7:25 AMUdon says:
Hey, great instructable.
I follow how it works, but I got a question.
I'm not sure if this has been asked and answered yet, but, what is the shunt in the MOT?
What does it do, and what affect does it have on the transformer?
Thanks
Jun 23, 2010. 4:54 AMmaxpush99 says:
It would help if you try to have the 2 windings in resonance. after you remove the secondaru windings you should weight it you use the same amount of copper by weight in your new winding,\ Just calculate lenght by thickness or weight the new windings good luck
Nov 4, 2009. 9:38 AMstudent.mckinney says:
But just think of all that fine guage wire that was wasted..... I have like 50 spools of wire from transformers, I just cannot let go of those little guys....
Apr 2, 2010. 3:18 PMscarabeetle101 says:
 *electromagnets*
Apr 4, 2010. 8:22 PMstudent.mckinney says:
I use it for electromagnets, I wind my own guitar pickups, use it on pcbs, etc... Great stuff!
Apr 14, 2010. 12:53 PMqwertyboy says:
It would take FOREVER to unwind all that wire. It would be just easier to cut it off like he did. Maybe you could brng all that copper to a recycling center for some money.
Feb 19, 2010. 12:59 PMrimar2000 says:
This question is addressed to several authors of welding related instructables.
Some time ago I was excited with the possibility of constructing a spot welder, but here in my city there is no way to get an
used microwave transformer: nobody throws away something as that.
Then I tried with my 220-volt electric welder, but I could hardly weak solder some iron wires of 2 mm, even though I was a good time trying.
Today I decided to uncover my welding machine, and found that in the secondary winding there is no place to put
even a loop of thin wire. But in the primary, yes!
I think I can easily add several turns of thick wire, by way of a "bis" secondary winding. Now come the doubts, and related questions: whether the primary winding has 248 turns (more or less, it is what I could count), and get 220 volts, it is assumed that each round of "my" coil will produce 220 / 248 = 0,887 volts. What for me? Put only one or two turns, or try to reach five or six? A more laps, more volts but less amps. I suppose that losses play an important role in the case of small voltages, and who knows what is best.
Maybe you has an answer and save me the work of trial and error, which can become very tedious. Thanks in advance!
Mar 3, 2010. 5:08 PMrimar2000 says:
Thanks for your kindness, jds1969.
Feb 10, 2010. 12:13 AMjerkey says:
Keeping the shunts in the transformer was a good idea.  They serve the function of limiting the total current, in my understanding.  Without the shunts, you would have a very hard time keeping from blowing the circuit breaker.
You should mention something about getting a bit of soldering flux, and brushing that onto the work before spot welding.  It can make the difference between a great weld and a poor one.
Great instructable!
Dec 29, 2009. 9:59 AMrimar2000 says:
Very, very interesting.
I don't have a Microwave Oven Transformer, but one of 220 to 110 V, 500 mA.
¿Do you think that transformer can be useful? Consider I live in Argentina, the line is 220 V.
Here is not easy to obtain a Microwave Oven in the trash...
Dec 29, 2009. 5:41 PMrimar2000 says:
Thanks, I feared that.
Dec 12, 2009. 4:23 PMLa Rotta says:
 Awesome! For further imrpovement, you may add a spring-loaded pedal. Pressing the pedal closes he jaws over the piece and start the welding. Releasing the pedal opens the jaws and opens the circuit.
Jan 20, 2009. 5:11 PMBobbDobbs says:
For additional safety I would take the ground wire from the cord (using a three prong plug) and tie it to the transformer case (drill and tap a machine screw into the core) and also tie the ground wire to one of the tongs, probably the stationary one. The purpose of this is that if there are any unintentional shorts, it should trip the circuit breaker rather than floating at a high voltage waiting for you to touch it.
Nov 4, 2009. 9:57 AMstudent.mckinney says:
Yeah, that is a fate that nobody should have to meet. I recently shorted out a damaged PS with my hand and that is not a fun experience..
Nov 4, 2009. 9:49 AMstudent.mckinney says:
Yeah, and the primary can have anywhre from 200 to 3000 turns, depending on your transformer. That means that  if you have 4 turns on the secondary, and the transformer primary has 2200 turns, you've got yourself a 110v 60Hz to .2v 33kA transformer. So that's 550 times greater amperage on the secondary than the primary. Wear some rubber gloves.
Sep 12, 2009. 7:51 AMjefftecklenburg says:
will this work on car fenders?Or what range of material gauges have you tried
Sep 12, 2009. 7:40 AMjefftecklenburg says:
I think I will do this the welder worked so good.
Jun 17, 2009. 4:52 PMxBrainstormerx says:
Uhm i got a transformer and I took out the secondary wires already but what if I only got a 12 awg that is 2ft and 6" is that okay or is that too little?
1-40 of 131next »
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
17
Author:jds1969
