Homemade Sundial
Published
Introduction: Homemade Sundial
About: I like inventing, experimenting, rockets, film making, and more! I consider myself a teenaged genius. I feel that with enough time I could build anything.
I decided to show how to make a homemade sundial that tells time by the hour.
Step 1: Materials
What’s Needed:
A Right Triangle Shaped Item or a Straight Stick
Dirt or Sand
Compass
Optional: Watch
Step 2: Don't Cross This Line!
Using the compass, find north, then draw a straight line towards north.  Then draw another line horizontally through the vertical line.  Set the triangle on the line facing north; if you are using a stick, jam it into the center of the lines.  You can then use a watch to add on the exact hours.  The lines are set up in this pattern: North is 12 o'clock, East is 3 o'clock, South is 6 o'clock and West is 9 o'clock.
Step 3: Finish
This sundial could be used in an emergency situation or could just be a fun little project.  Please leave a comment.
    • Make it Move Contest
    • Casting Contest
      Casting Contest
    • Woodworking Contest
      Woodworking Contest
    3 Comments
    Thanks! The triangle method will operate for a quick check of time. For all day time telling, the stick will work best.
