3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Homemade Super Soaker Water Blaster
Step 6Fixing the water tank in place
cut a piece of pipe higher than the inlet of the pump
cut a dip in to it so it fits over the pressure chamber support
now cut a square out of it so the coke bottle cap fits in to it.
on the opposite side of the pipe cut a notch out so the copper pipes can stick out
now hot glue the cap in place making sure its fairly level.
Cut the 5mm hose so it’s short enough to go from the cap to the inlet on the pump with out bending more than is needed, then connect it to the pump
now hot glue the tank stand to the pressure chamber support.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
21
Author:n1cod3mus(Chris Fry Design)
I'm a web developer, IT engineer, Graphic Designer. I have a creative nature and an over reactive imagination which is perfect for instructables.
