Introduction: Homemade Tiny MotorBike Model
Picture of Homemade Tiny MotorBike Model
This homemade tiny motorbike model is madeup of scraps/used thing..
I have made it with used stationary items and some scraps...
Step 1: Sketch Basic Structure of Bike
Picture of Sketch Basic Structure of Bike
You can use any chassis structure which is easier for you to build
use internet, comeup with more options..
start building
Step 2: Tools You Will Need
1. Cutter
2. Ruler
3. Marker
4. Fabric Glue
5. Masking Tape
6. Compass/ Divider (to pin holes)
7. Screwdriver
Step 3: Thing You Need
1. Two Bearings (for wheel)
2. Some empty refills of Pen (it will be good if you use jell pen refills as its thinker than ball pen ones)
3. Candle (to give desired shape to the refills)
4. Screws to fasten everthing (of suitable size which fits the refill inner diameter)
5. Springs (easily available in some pens)
6. Bolt & washers
7. Clay
Step 4: Fixing the Things Up
Picture of Fixing the Things Up
The front wheel base is show in the image
Take two refills of appropriate length cutt with the help of cutter
Mark two pin holes at no it both extreme end (this hole it to fix screws in it
similary, mount the rear wheel base
Step 5: Hooke the Things Together
Picture of Hooke the Things Together
Step 6: Making the Replica of Engine
Picture of Making the Replica of Engine
Use a bolt and some washer
and fix it with the help of glue
On a Cylindrical member made with cardboard
Let it dry and paint it..
Attach it to the structure
Step 7: Fuel Tank & Seats
Picture of Fuel Tank & Seats
Use clay add some amout of glue in it & mix it well
(this is because to make the clay solid)
Mould the shape of fuel tank and seats
let it dry
paint it
mount it to the bike
you can use anythnig new/creative idea to make this things
Step 8: Adding the Final Touch
Picture of Adding the Final Touch
just look around you table u will find number of new ideas... :-)
Quanah (author)2015-06-08
Nice work.
DIY Hacks and How Tos (author)2015-06-06
NIce motorcycle. I bet you could use this technique for a lot of different styles of bike as well.
About This Instructable
855views
20favorites
License:
More by avishwakarma7:Homemade Hot Rod Vintage Car ModelHomemade Tiny MotorBike Model
Add instructable to:
