3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Homemade Vacuum Sealer
I came up with a way to use your vacuum cleaner and a space bag to vacuum seal food and other items.
Step 1Materials
Materials:
Vacuum cleaner or Shop Vac.
Space Bag (vacuum compression bag for clothes) with one-way valve and zip top.
Folded Cloth.
Ziploc Bags in your choice of size.
13 comments
Aug 20, 2011. 7:46 AMaudioworm31 says:
Ingenious idea.
Nov 17, 2010. 12:23 PMsprocketscientist says:
Awesome! I was pondering DIY vacuum food storage and vacuum bagging for sous vide cooking, and I had this exact same idea yesterday! Gonna try it later on today.
Aug 19, 2009. 1:07 AMspencernielsen says:
This is super crafty! I just bought some Space Bags and wanted to vacuum seal my food with out buying a machine. Thanks!
Jan 11, 2009. 10:29 AMFensterino says:
This sounds awesome...I can't wait to try it! Ingenious!
May 31, 2007. 10:10 AMdrcrash says:
Food sealers generally use considerably stronger vacuum than a vacuum cleaner can provide. My Food Saver II pulls 23+ inches of mercury (29.9 is a perfect vacuum), but even a very good vacuum cleaner only does 4 or 5, possibly 6 for an expensive two-stage vacuum cleaner.
Here's an alternative vacuum source that pullls 24 inches or so, made from a cheap (tire inflator type) air compressor:
http://www.instructables.com/id/E791HNXF23Z39P6/
If you want to make a better food sealer, you might try it.
Jun 24, 2007. 8:28 AMdrcrash says:
Here's an instructable on making a manual vacuum pump from a bike pump, for less than $20. It would be suitable for vacuum sealing food.
http://www.instructables.com/id/EA58LR1F35J1I9N/
May 7, 2007. 1:26 PMtjb says:
This would save fortune on space bags though if it works with the huge ziplocks for storing clothes and bedding and stuff that I don't want to get musty or the moths and spiders into on the off seasons. I use garbage bags in big stacked containers and if this could reduce the storage without all the money on space bags it would be wonderful. I'll have to give it a try - might be a great hack! Not just for food, can seal clothes and tax records, etc. I have lots of stuff in temp. storage.
Oct 7, 2006. 10:24 PMCbrown says:
This is brilliant, maybe someone should post an instructable on making a vacuum sealer- maybe out of an old vacuum engine and some pipe fittings. I would but i don't have an old vacuum engine
Aug 28, 2006. 10:18 AM0.775volts says:
If you're going to seal in liquids or semi-liquids like that, you need to put them in a container that does not collapse. you can still pull a vacum, and not have to worry about pulling out the food/soup/whatever. I like the idea, it's very innovative.
Aug 27, 2006. 8:02 PMradiorental says:
I think you're going to have issues dealing with semi liquid foods (fish/soup/mashed potatos/mashed potato fish soup) Buts its a really good idea. I guess you would need some way to hang the ziplock bag inside the vacuum bag (punch a hole in the 'outside' part of the seal and have a hook in your vacuum bag) But I still feel this might be a hit or miss or messy operation. I've seen industrial food sealers in operation, thats an entire chamber, two plastic sheets and a frame that heats the sheets shut, very hard to replicate on a modder scale
Aug 27, 2006. 7:45 PMColumbusGEEK says:
Seems like a lot of work to me. Of course I like Miller High Life beer so I am not a good judge of anything.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
Author:Randy_che
