3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Homemade Wakeboard, Wakeskate Winch From BeachWinches.com
Here is a simple wakeboard, wakeskate winch that you can bring anywhere. Ride your wakeboard or wakeskate places a boat can not go. This is a very exciting project and for more info about beach winches go to http://www.beachwinches.com
You can use this winch for wakeboarding, wakeskating, skimboarding, snowboarding, etc. so this one winch is a very verstile machine.
*Update
Here is a short video describing what a beach winch is.
Step 1First the Spool
First the Spool
First I built the spool
Here is my spool. I do cnc machining so I cut my spool walls out of heavy duty plastic. I am confident it will work just fine because i've seen it used before. If it doesnt work I will replace it with steel walls.
Materials:
1/2 all thread.
1/2" galvenized pipe.
threadlocker.
ny-lock nuts.
Go Kart hubs.
washers.
etc.
37 comments
Oct 11, 2010. 10:15 AMAllonsy says:
this is awesome. and i havnt even read it yet.
Oct 17, 2011. 7:07 AMflorman says:
I was just wondering if there was a way to make it continues.
Aug 27, 2011. 11:03 PMworldburrito45 says:
would it work if you used a old rim off a car (probably very small one) as the spool?
May 15, 2011. 2:47 PMThomasSmith says:
One more question, what was the total width of your spool walls? I found one that has a width of 15 inches. Would this be too big to fit into your frame?
Thanks
May 12, 2011. 6:39 PMThomasSmith says:
I am currently buiding your winch and following your design and I have just about everything except the sprocket. I was wondering if you could help me find the sprocket you used?
Thanks
May 1, 2011. 11:14 AMfatty_inc says:
Why did you start with centerifugal clutch? I am trying to figure out if I want to get the tav 2 clutch or the one you used. What are the main differences.
Apr 15, 2011. 5:41 AMmdoucet says:
where do you get the bolt on bearing holders...the green things
Feb 24, 2011. 5:56 AMlrobson says:
hi mate your winch is a good idear just wondering if you could help me where did you get your middle hubs from ? i have made this winch up and is stead of making a spool i done one out of a cr rim and put metal around the out side to make my spool did not work ever well so i am going to do it propley and folow your desin.
thanks
Nov 24, 2010. 8:50 PMbenthekahn says:
I finished mine today. It pulled a skier on grass for about 50 feet before the connecting link broke. I welded the chain, so it should be good for a while now.
Oct 18, 2010. 5:30 AMbazery says:
Quick question about the hubs, do the hubs have a groove to lock into or do they have a screw against the bar.
If there is a slot how does if fit the pillow block.
I think if i could see more pics of the shaft and the hubs on the shaft I would understand.
I'm in the process of building the frame, spool is the next project.
Great ible by the way
Oct 15, 2010. 12:29 PMelectro says:
How about having a collar on the rope at a set distance from the end. When the collar enters a hinged split tube that is slightly narrower than the collar it activates a kill switch for the engine. That way there wont be any mishaps when the operator get too carried away spectating and the handle gets jammed on the spool !!
Oct 11, 2010. 3:49 AMrichiendn says:
TC2 1002 Replaces Comet 218353A TAV2 30-75 Torq-A-Verter which is no longer manufactured.
http://gokartsusa.com/Baja-Heat-Minibike-TC2-Torque-Converter.aspx
Oct 7, 2010. 10:41 AMTeamSlash says:
I am going to use this to Paraglide with... Static line towing sweet!
Oct 9, 2010. 7:14 AMpantarhei says:
I hope you know what you are doing. AFAIK this type of winch is not suitable for paragliders and it would be very, very dangerous.
Oct 7, 2010. 11:08 PMmikejs says:
This is fantastic. I've been contemplating a DIY build like this for a while, thank you for putting together the instructions.
Any sense on what the speed is for the winch?
Oct 7, 2010. 10:26 AMsyco123 says:
Make 2 and put one on each opposite shore and tether the non pulling one to your back. Then you could ski all day with minimal fuss.
Oct 7, 2010. 3:37 PMstevezone says:
much simpler and cheaper than building 2 units... to run the rope as a loop then just grab the opposite rope to go the other way
Oct 7, 2010. 9:30 AMjstoner says:
This is a really cool concept, something I had never heard of. I had to go google around to find a video to figure out what the heck 'beach winching' was. Looks like a lot of fun though.
Here's a question: does anyone mess with a loop system? Instead of a winch pulling the rope in one direction, you'd have a loop of rope and (at least one) pulley down the beach, and you'd run the rope around and around the loop and surf on that loop out in the ocean. You could even have more than one person on the loop at a time.
Oct 7, 2010. 1:17 PMjstoner says:
beachwinches.com is great if you already know what it is and you want to get involved. If you've never heard of such a thing, I think this is more straightforward:
http://www.broadbandsports.com/node/5808&gvsm=1
Oct 7, 2010. 9:03 AMLongchamp says:
Can someone explain the concept behind what beach winching is? I cant really find a text description anywhere.
Do you just swim out with the end and it tows you back in quickly?
Oct 7, 2010. 10:59 AMtrs5 says:
Hi I have a question? does someone have to manual stop the motor? I'm trying to think of a way to have it shut off when the line is at a certain length. I always wanted to wake board via winch! no good places to do it near me
Oct 6, 2010. 7:04 AMbillytwix says:
well done! i figured the hubs were go cart.
Oct 5, 2010. 10:02 AMantidoteco says:
sick !
Oct 5, 2010. 12:12 AMmikeasaurus says:
nicely documented. you should include an edited version of the video from your website here to illustrate it's use.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
11
Author:Rockout101(Beach Winches)
Beach Winches can go places where boats can not go. These winches can take wakeboarding anywhere. Check out our website: www.beach winches.com
