Introduction: Homemade Wood Metal Lathe Very Cheap
Homemade Mini Lathe Chuck Wood Metal Axis Tailstock DIY Router Spindle How to Make Drill CNC Machine
DIY Wood Mini Lathe Metal Axis Homemade Tailstock with Motor Drill very cheap and easy:
Parts and Tools:
Wood MDF 200 mm x 650 mm x 20 mm
2pcs SCS10UU 20 mm Linear Ball Bearing Motion Bearing CNC
2pcs 400 mm 20 mm Linear Rails
Aluminium Alloy Profile 1200 mm x 40 mm x 20 mm
Aluminium Alloy 6061 120 mm x 80 mm x 40 mm.
Lathe Chuck 80 mm
2 pcs Linear shaft 35 mm x 20 mm aixs .......
BeachsideHank (author)2015-05-15
Given the nature of the tool, I think I would double up the MDF thickness for better harmonic damping, and more rigidity between the headstock and lathe bed.
About This Instructable
5,094views
82favorites
License:
More by joulethief669:DIY Axi Draw Bot 4xiDraw Robotic Pen AxiDraw Homemade Robot 3D Printer Plotter CNC Laser ArduinoHomemade Laser Engraving Plotter DIY Pen Draw Mini Machine CD RW DVD Drives Mechanism CNC ArduinoHomemade Wood Mini Lathe Collet ER11 Drill DIY Headstock Chuck Spindle Tailstock Slide Mill CNC
Add instructable to:
