Homemade Wood Metal Mini Lathe Collet ER11 DIY Headstock Chuck Spindle Tailstock Slide CNC Milling
926
10
Posted in WorkshopWoodworking
Introduction: Homemade Wood Metal Mini Lathe Collet ER11 DIY Headstock Chuck Spindle Tailstock Slide CNC Milling
Materials:
1 pcs SK 25 linear shaft support 25mm Linear Rail Shaft Support XYZ Table CNC SHF Series Rail Shaft
1 pcs motor 50 watt take from old hand drill
1 pcs ER11 Motor Shaft Extension Rod Inner Hole 8 mm Optional Engraving Machine Clamping Collet Drill Sleeve Motor Extension
1 pcs Special round steel pipes 25 mm x 40 mm
1 pcs Special round steel pipes 8 mm x 60 mm
1 pcs Aluminium 150 mm x 40 mm x 20 mm
1 pcs strength aluminum alloy 42 mm Motor bracket DC Motor Fitting
More Homemade mini Milling DIY X Y Z Slide CNC Drill Home Built Lathe Router Machine
    • Spotless Contest
      Spotless Contest
    • Trash to Treasure
      Trash to Treasure
    • Pocket-Sized Contest
