Homemade Wood Metal Mini Lathe Collet ER11 DIY Headstock Chuck Spindle Tailstock CNC Router Milling
Published
Introduction: Homemade Wood Metal Mini Lathe Collet ER11 DIY Headstock Chuck Spindle Tailstock CNC Router Milling
Materials:
1 pcs strength aluminum alloy 42 mm L Motor bracket DC Motor Fitting
1 pcs Aluminium 100 mm x 70 mm x 35 mm
1 pcs motor 50 watt take from old hand drill 1 pcs ER11 Motor Shaft Extension Rod Inner Hole 8 mm Optional Engraving Machine Clamping Collet Drill Sleeve Motor Extension
1 pcs Special round steel pipes 25 mm x 40 mm
1 pcs Special round steel pipes 8 mm x 60 mm
More Homemade Scara Robot Arm DIY Robotic Frame Projects Laser 3D Printer Draw here:
    • Woodworking Contest
      Woodworking Contest
    • Make it Move Contest
    • Casting Contest
      Casting Contest
