Homemade Wood Metal Mini Lathe Collet ER11 DIY Headstock Chuck Spindle Tailstock Slide CNC Router
876
12
Posted
Introduction: Homemade Wood Metal Mini Lathe Collet ER11 DIY Headstock Chuck Spindle Tailstock Slide CNC Router
1 pcs high-strength aluminum alloy 6061 42 mm Motor bracket dc Motor Fitting
2 pcs SZS Wholesale FL08 2 Bolt 8mm Bore Self-aligning Flange Ball Bearing
1 pcs motor 50 watt take from old hand drill
1 pcs ER11 Motor Shaft Extension Rod Inner Hole 8 mm Optional Engraving Machine Clamping Collet Drill Sleeve Motor Extension
1 pcs Special round steel pipes 8 mm x 16 mm
1 pcs Aluminium 70 mm x 50 mm x 35 mm
1 pcs Aluminium 120 mm x 70 mm x 12 mm
More Good Projects Step by Step Homemade Mini Lathe DIY Wood Milling CNC Router here:
    • Science of Cooking
      Science of Cooking
    • Microcontroller Contest
    • Spotless Contest
      Spotless Contest
