Introduction: Homemade Wood Metal Mini Lathe Collet ER11 Drill DIY Headstock Chuck Spindle Part 2
Homemade Chuck Spindle DIY here:
Materials:
2 pcs linear rail 12 mm 300 mm linear shaft chromed precision hardened rod linear shaft cnc parts
1 pcs Aluminium 90 mm x 50 mm x 35 mm
1 pcs SK 25 linear shaft support 25mm Linear Rail Shaft
1 pcs motor 50 watt take from old hand drill
1 pcs ER11 Motor Shaft Extension Rod Inner Hole 8 mm Optional Engraving Machine Clamping Collet Drill Sleeve Motor Extension
1 pcs Special round steel pipes 25 mm x 60 mm
1 pcs Special round steel pipes 8 mm x 80 mm
1 pcs Aluminium 90 mm x 70 mm x 25 mm
1 pcs Aluminium 85 mm x 42 mm x 12 mm
1 pcs Aluminium 70 mm x 100 mm x 6 mm
1 pcs Aluminium 80 mm x 40 mm x 12 mm
1 pcs Aluminium 90 mm x 40 mm x 16 mm
More Good Projects Step by Step Homemade Mini Lathe DIY Wood Milling CNC Router here:
About This Instructable
503views
13favorites
License:
More by joulethief669:DIY Axi Draw Bot 4xiDraw Robotic Pen AxiDraw Homemade Robot 3D Printer Plotter CNC Laser ArduinoHomemade Laser Engraving Plotter DIY Pen Draw Mini Machine CD RW DVD Drives Mechanism CNC ArduinoHomemade Wood Mini Lathe Collet ER11 Drill DIY Headstock Chuck Spindle Tailstock Slide Mill CNC
Add instructable to:
