Homemade Wood Metal Mini Lathe Collet ER11 Drill DIY Headstock Chuck Spindle Part 1
723
13
Posted in WorkshopWoodworking
Introduction: Homemade Wood Metal Mini Lathe Collet ER11 Drill DIY Headstock Chuck Spindle Part 1
Materials:
1 pcs SK 25 linear shaft support 25mm Linear Rail Shaft Support XYZ Table CNC SHF Series Rail Shaft
1 pcs motor 50 watt take from old hand drill 1 pcs ER11 Motor Shaft Extension Rod Inner Hole 8 mm Optional Engraving Machine Clamping Collet Drill Sleeve Motor Extension
1 pcs Special round steel pipes 25 mm x 60 mm
1 pcs Special round steel pipes 8 mm x 80 mm
1 pcs Aluminium 90 mm x 70 mm x 25 mm
1 pcs Aluminium 85 mm x 42 mm x 12 mm
1 pcs Aluminium 70 mm x 100 mm x 6 mm
1 pcs Aluminium 80 mm x 40 mm x 12 mm
1 pcs Aluminium 90 mm x 40 mm x 16 mm
More Homemade mini Milling DIY X Y Z Slide CNC Drill Home Built Lathe Router Machine
    • Woodworking Contest
      Woodworking Contest
    • Make it Move Contest
    • Casting Contest
      Casting Contest
