Homemade Wood Metal Mini Lathe Projects DIY Headstock Chuck Spindle
Published
Introduction: Homemade Wood Metal Mini Lathe Projects DIY Headstock Chuck Spindle
Homemade machining spindle intended for utilization in conjunction with a mini wood lathe machine. Fabricated from steel stock measuring 12 mm in diameter x 120 mm in length, 2 pcs bearing 32 mm / 12 mm, Chuck drills, Aluminium alloy, old motor take from old hand drills, it is very cheap and easy for build in home, it is nice work long times
More Step by Step Homemade Mini Lathe DIY Wood Milling CNC Router here:
    • Make it Move Contest
    • Casting Contest
      Casting Contest
    • Woodworking Contest
      Woodworking Contest
