Homemade Wood Mini Lathe Collet ER11 Drill DIY Headstock Chuck Spindle Tailstock Slide Mill CNC
Published
Introduction: Homemade Wood Mini Lathe Collet ER11 Drill DIY Headstock Chuck Spindle Tailstock Slide Mill CNC
Materials:
2 pcs SZS Wholesale FL08 2 Bolt 8mm Bore Self-aligning Flange Ball Bearing
1 pcs motor 50 watt take from old hand drill
1 pcs ER11 Motor Shaft Extension Rod Inner Hole 8 mm Optional Engraving Machine Clamping Collet Drill Sleeve Motor Extension
1 pcs Aluminium 100 mm x 60 mm x 12 mm
1 pcs Aluminium 90 mm x 70 mm x 35 mm
1 pcs Aluminium 90 mm x 80 mm x 35 mm
1 pcs Aluminium 70 mm x 50 mm x 35 mm
1 pcs Aluminium 80 mm x 42 mm x 12 mm
2 pcs 12 mm x 300 mm linear shaft cylinder linear rail linear shaft axis cnc
More Good Projects Step by Step Homemade Mini Lathe DIY Wood Milling CNC Router here:
    • Make it Move Contest
    • Oil Contest
      Oil Contest
    • Casting Contest
      Casting Contest
    hello,
    very interesting! But, where to buy the material?
