Introduction: Homemade Wood Mini Mill Lathe Machine for DIY in Home
Description:
1. This DIY miniature small wood lathe is simulated, simplifying the large lathe working principle, extensive use of high-strength aluminum alloy materials, CNC machining, for research using and DIY.
2. DIY products for school experiment teaching or personal DIY use, not suitable for mass production or commercial use.
More Step by Step Homemade Mini Lathe DIY Wood Milling CNC Router here:
Feature:
1. High accuracy, stability, low noise, strong power
2. Thick aluminum base, acrylic dust cover motor
3. Variable speed, large torque ball bearing motor
Parameter:
1. Input voltage: 12V DC
2. Power: 80W
Homemade mini Milling DIY X Y Z Slide CNC Drill Home Built Lathe Router Machine
3. Speed: Max:8000rpm (Seven stall speed regulation)
4. The theoretical maximum turning diameter: 70mm
5. The theoretical maximum clamping length: 180mm
6. Chuck clamping range: 0.6-6mm
7. Long With Hight:: 400mm x 80mm x 90mm
About This Instructable
1,684views
40favorites
License:
More by joulethief669:DIY Axi Draw Bot 4xiDraw Robotic Pen AxiDraw Homemade Robot 3D Printer Plotter CNC Laser ArduinoHomemade Laser Engraving Plotter DIY Pen Draw Mini Machine CD RW DVD Drives Mechanism CNC ArduinoHomemade Wood Mini Lathe Collet ER11 Drill DIY Headstock Chuck Spindle Tailstock Slide Mill CNC
Add instructable to:
