Homemade X Y Z Axis Slide for DIY CNC Router Milling
Published
Introduction: Homemade X Y Z Axis Slide for DIY CNC Router Milling
Homemade mini Milling DIY X Y Z Slide CNC Drill Home Built Lathe Router Machine
Perfect to fit the most critical part of your home made or professional CNC project.
More Good Projects Homemade Nice Work for DIY Handmade here:
More economic, more precise, than if you try do it yourself, keep your effort and money for the rest of your project.
Stepper Motor already coupled and installed.
Easy mounting, thanks for the plenty of holes on the back side.
Z axis stroke: 135 mm.
Main dimensions: 400mm X 125mm X 100mm.
Ballscrew Shaft : The outer diameter is 10 mm, the pitch is 2 mm.
Double ball nut.
Aluminum alloy coupling.
Stepper Motor : 56 mm
Linear Guide: 20mm chromed harden linear
4 pcs 20 mm Linear Motion Ball Bearing Slide Bushing Linear Shaft
The housing material : aluminum alloy.
    • Clocks Contest
      Clocks Contest
    • Casting Contest
      Casting Contest
    • Woodworking Contest
      Woodworking Contest
