Before I get started, I have to give props to Geoff Milburn, at
http://www.gmilburn.ca/ac/ whose plan it was I copied. I'm not smart enough to think up something like this on my own. That being said, one of the places I work has no AC, but I'm allowed to have fans, so this seemed like a good project for me. It's not perfect yet, but it does cool the air better than just a fan.
I took the grate off of my fan, so I could put the heat exchanger on the inside, hopefully making it look better. I'm using copper tubing as the heat exchanger, although you could use something else, as copper is not cheap, and not easy to work with. As you can see in the second photo, it's very easy to kink the tubing, in which case, you stop the flow of water. I grabbed a hole saw to use as a die to wrap the tubing around, and the teeth held nicely against the grate of the fan. As I was going along, I used zip ties to hold the tubing to the grate. Of course, because this will be inside the fan, make sure to clip off the loose ends. Also, make sure that you have both ends of the copper tubing sticking out of the fan, so you can hook up the tubes to the pump.
and if yes then does it cools as ac or not
I'm currently working as an intern to get my CC license and in about two years my C and hopefully go on to my Agency license if all goes well. It's fun work, but very HOT!
It really works great when you have everything right and saves so much energy. All you need is 8000 BTU's blowing right at you to keep you cool on the hottest day. Of course, when you leave your cool place the whole rest of your home is hot but who cares?
So far I am happiest with the styro-foam box top with a hole cut out for the 3"x8' air duct but it doesn't allow the hot air to flow away from the unit freely enough. I haven't yet found that perfect compromise between totally free air flow like you get in the window and some kind of control which I am working on. The fabric worked great but I felt bad knowing that all I had accomplished was slowing the air down to a stop after eight feet. Essentially, the fabric air duct turned into a fabric tail that just sort of held on to the hot air for a while. But it was enough to get the air condition working. If you don't have enough air flow in the back the air condition will not work except as a fan.
The beauty of my plan is that you can use your cheap air conditioner as a heater in the winter and an air conditioner in the summer by just changing the position of the air duct from the front to the back.
Has anyone worked on this and if so, what do I need to do to get the right air duct? I would like air duct that blows up like a balloon. In fact, my next step will be to try one of these 60 foot solar balloons which are 72 inches in diameter. The air condition is 60 inches around the box so the 72 inches will be great. I will attach one end of the solar balloon to the air condition and cut the off the other and throw it out the window and if that works.
If it works, then I can just move the balloon around from the small bathroom window to the defunct ducts from my former central air conditioning system and even up through the vent above the stove. Ideally I would like a very flexible, but strong, material, like the solar balloons. They look good.
Any ideas?
1. Is there a cheaper alternative to Copper Piping?
2. Would an older pool pump work for the water pump?
Thanks in advance.
@ jmeyerson2 the longer the better it is but not too long as it may block the airflow and cooling ability will be affected.
Haha, I starting to build your instructable now! - just wondering where to get hold of the copper piping? - probably a hardware store?
how cool air does this thing make ?
