Step 2Attaching the tubing to the pump
iImage Information
Now, the cheapie pump I bought would only fit 1/2" ID tubing, and they didn't have anything that would downsize it to 1/4" for me, so I just rigged it up. As you can see in the first and second photos, 1/4" tubing fits quite nicely around the copper tubing. In the third photo, you can see how I just inserted the 1/4" into 3/8", into 1/2" tubing, which would then fit onto the pump. This of course leaked, which necessitated the use of hose clamps, photo 4. I feel that this greatly reduces the effeciency of my pump, but now I have a reason to buy a bigger, stronger, more manly pump! Either that, or buy bigger copper tubing, which is not as exciting.
The problem I see is with the pump, it should be powerful enough to send the water across the copper tube. Recommend one with at least 1,500LPH. As I have a small water pump same as per picture above and it only provides 230LPH.
Are you sure a small water pump would be enough for the water to flow?
You're suggesting that freezing water using similar if not identical technology (so same efficiency) and then using electricity to pump it around as well is going to be more efficient than an air conditioner, which doesn't have the additional pump? When an air conditioner, might I add, doesn't just throw the waste warm air back into the room anyway but blows it outside, unlike a freezer, which won't actually remove any heat from the building at all?
A/C is more efficient. Just a big initial investment.
Now, in your example, you say your freezer has plenty of space. If that's the case, then it should only run to keep that amount of "solids" cool. When you use the ice cubes, for example, in the cooler from this article, and then fill the ice cube trays, your freezer will then run to make new ice. This in turn generates more heat (and the amount of heat generated will be greater than the amount of cool that the ice cubes generate). Think about it this way, if this kind of thing were truly feasible, why not just leave your freezer unstocked and opened to cool your house? Because it's not 100% efficient. The inefficiency is reflected as heat (not to mention the electricity).
I realize I'm not very good at explaining Thermodyamics, suffice to say that your freezer is far more efficient than this fan and a copper tube. I'd even go so far as to say if you REALLY wanted to run something like this, then buy a freezer, drill holes in it and run the copper tube through the freezer into your fan. At least then it's being cooled by something more than ice cubes (and you're not potentially wasting the water to produce the ice).
I'll refer you to this article and maybe it'll make more sense :).
http://en.wikipedia.org/wiki/First_law_of_thermodynamics
I get it.
...Well...I got it to begin with...but I still get it, and you're still right.
The home is acting as a closed system, so.. without taking into account the fact people are moving in and out of the home...there is no mass coming in the is no mass coming out. However energy is being passed through due to ambient losses through walls and windows.... ideally heat in=heat out therefore in order to make the ice, heat has to be transferred from the water to..somewhere to make ice, this heat is transferred into the home and diffuses into the air therefore making the home warmer... the ice then can only cool the home back to its original temperature due to the laws of conservation of energy. therefore since heat is still coming into the home from the outside environment more heat is being put into the home than being taken out.... therefore heat in>heat out so.. already in an ideal world this unit is not cost effective....
however this is pretty awesome.
When a freezer is running, it isn't permanently "running". It maintains a temperature. If you add a big bottle of room temperature water to your freezer, it has to work harder to cool down that water and freeze it, and harder still to cool down the air you let in when you opened its door. The actual cooling of a freezer has similar efficiencies as an AC. The wasted energy in cooling the air you let into the freezer, and cooling the hot air a freezer releases into your home, makes an AC much more efficient overall.
In the long term an AC will cost less to run than this, assuming you use both to achieve the same temperature changes over the same period of time. And most ACs have thermostats and controls that allow the user to reduce cooling if they don't need that much.
http://cgi.ebay.com/NEW-HEATSINK-EXTRUSION-10-125-WIDE-ALUMINUM-HEAVY-BIG_W0QQitemZ170364201291QQcmdZViewItemQQptZLH_DefaultDomain_0?hash=item27aa7f694b&_trksid=p3286.c0.m14#ht_500wt_1182
He should have different lengths available that are cheaper but that's the kind that works best for TECs. Also you need to have some thermal glue to get the hot side of the TEC to stick to the most surface area of the aluminum. they have to be held on their super tight in order to work the most efficiently since sometimes they can warp slightly. I ran into the same problem when I had I tried to use TECs with solar power. If the current is too high for your heat sink, both sides will get extremely hot. Also it is important to note that when you turn the power off, the cold side will get really hot and the sudden temperature shifts will warp the TEC so sometimes like in aquarium chillers, they have another heat sink on top of whatever you're cooling to dissipate the heat that comes back.
