loading
.3g of my homemade black powder. It has some fair go to it..
75 KNO3
15 C6H7O
10 S
Not too hard to make, it's fairly fine and fast but it doesn't come across excellently on my crappy kodak camera. At the moment I'm turning a small cannon..stay tuned.
hey man how dangerous or likely is it to auyoignite. im 15 and want to make some for model rockets but my parents think it would go off if i dropped it or something
<p>Blackpowder? It's pretty popular, it'd be famous for being sensitive if it were. Blackpowder explodes though, I think you'd want RCandy as a propellant.</p>
You can a actually get all these parts in the hardware store, kno3, saltpeter, you can get in Lowe's as Spectracide stump remover, about 5 or 7 bucks a pound 99 percent pure, but it is as coarse as sugar granules, so you will have to mill it. Charcoal can be bought in stores or made using wood, and you can sometimes get sulfur as a fertilizer for plants, though sulfur is the hardest to find, if you guys on a budget can't find sulfur I recommend making sulfur less black powder. And there you have it: you can now make any size bomb or grenade or even a musket with items you can pick up at a hardware store. I LUV AMERICA, <br>
WTF HOW DID THIS COM UP WHEN I SEARCH KNEX BALL MACHINE THIS IS A BALL KILLER!!!!!!!!!!!!!!!!!!!!!!!!!!
knex got dissed.
good starting mix, did you ball mill it? if not that's something I'd consider doing, as it vastly increases quality. is that ascorbic acid in place of charcoal? As that may also be reducing the overall quality
It's charcoal.<br/><br/>It's milled to as fine, probably finer than meal.<br/><br/><a rel="nofollow" href="http://www.musketeer.ch/blackpowder/history.html">http://www.musketeer.ch/blackpowder/history.html</a><br/><br/>And oops, I stuffed up the numbers. should have been C7H4O, not C6H7O :)<br/><br/>&quot;A mixture of homogenized saltpeter (KNO3) and charcoal (empirical formula C7H4O). Confined into a closed space, this mixture explodes violently if heated up to 400 centigrade. By adding sulphur to this mixture, the ignition temperature is reduced significantly. The mixture containing sulphur develops white smoke versus the sulfurless powder burns near smokeless.&quot;<br/><br/>My charring process isn't hot enough for my charcoal to be pure carbon, I might use an oxy-fuel torch and try that some day.<br/>
Looks good but why is this in knex??
read the tags, was kinda dissing knex..
About This Instructable
14,779views
57favorites
License:
Bio: 17 Years old, doing a Masters in Professional Engineering (chemistry/mechanical) starting at UWA next year. I like designing and building things, as well as ... More »
More by nonickname:Knifemaking tutorial: Japanese Kiridashi Using GIMP to manipulate photographs and images Homemade 400 psi airgun
Add instructable to:
