3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Homemade bottle rockets
A while back my friend asked an easy way to make a bottle rocket .....so this Instructable was born
  • Make sure to wear the proper protective gear such as some kind of glasses for eye protection, safety glasses would be best .....
*some sort of breathing protection would also be advised
  • gloves help as well so you don't burn yourself
Check the video for a picture of me dressed like a ninja with homemade safety wear and my first three rocket launches
I tried embedding it but alas, photo bucket is lame. so you get a crappy long link ....YAY
http://s46.photobucket.com/albums/f136/goawayndstay/?action=view&current=ceec0f6c.pbr
PS. if you like it ....rate it up .....don't flake !
Step 1What You Will Need
What You Will Need
  • last photo ←
1. Post its
2.A Hammer
3. a small bit of fuse
4.a small mixing bowl
5.A mortar and pestle
6.needle nose pliers
7. duct or scotch tape
8. wooden skewers
9.A Pencil
10. A nail
11. Black Powder
12.kitty litter
  • Pictures of these will be listed in order below
227 comments
1-40 of 227next »
Aug 22, 2010. 8:00 AMRhayel72 says:
i think sand would do the trick...
Feb 5, 2011. 3:55 AMWendyLD3 says:
what is a good tested black powder sub
Nov 15, 2011. 7:51 PMhighvoltageguy says:
finnally a new picture (me)
Jun 23, 2009. 7:36 PMProud American Pyro says:
Can you use something like flash powder instead of black powder?
Oct 20, 2011. 1:53 PMEric T says:
You could use flash powder in the tip then it should explode at the end of the burn.
Oct 23, 2009. 9:44 AMnorge says:
Flash powder burns way too fast, just gonna explode once the fuse reaches the powder ;) so the answer is no, you can't use flash as "rocket fuel".
Aug 24, 2011. 1:37 PMspark master says:
wax the pencil then use glue after the first 1.5 wraps . Use removable tape to hold in lace til dried remove that less waste and lighter. Use exterior wood glue it dries hard and waterproof, you can coat the entire outer tube when done and wrap a paper label over the stick (which is glued on as well) . Mount a nail of correct size through a board and then you can pour stuff in from the top and tamp away knowing you will have right hole right length (trial and error will get you the right length, but then you have it)
Jul 4, 2011. 4:26 PMcodycnnn04 says:
How did you know that the nail would be a big enough nozzle for the right amount of thrust for the rocket, without detonating the rocket or being to little thrust?
Thnx.
I I
Dec 6, 2010. 10:01 AMcelticrush97 says:
what other powders can you use and wheir can you find them?
Jun 16, 2010. 6:21 PMab02s says:
Use small straw instead of post it and you will get a nice smoke trail and is easier than taping the paper into a cylinder. Awsome otherwise!
Oct 31, 2010. 12:55 PMlucius108 says:
no man it needs to be solid after compression and i dont think dirt will do the trick
Jul 9, 2010. 6:55 PMwizkid7 says:
Could dirt be used as a substitute for kitty litter?
Oct 31, 2010. 12:53 PMlucius108 says:
Oct 1, 2007. 3:30 AMsikkmate says:
sweet i just have a quick question is black powder just gun powder like out of bullets??? and does the skewer go flying with the rocket wen it lights
Jul 1, 2010. 4:06 PMairsoftjunke says:
black powder is "old school" and was used in muzzle loading riffles(think lewis and clark). the gun powder in new age ammo is smokeless and less explosive but burns quicker building up gases to propel the projectile to its target. bottom line: they are two different things.
Apr 25, 2010. 7:42 PMtigerboy says:
dumb question, will adding kitty litter in the middle and make a large nozzle and then add more powder and cap it...make it a single stage with a explosion at the end?
Jun 7, 2010. 9:52 AMYoungPyro19 says:
Is this it?==> http://www.amazon.com/Pyrotechnics-George-W-Weingart/dp/0820601128/ref=sr_1_4?ie=UTF8&s=books&qid=1275929469&sr=1-4
Apr 25, 2010. 7:32 PMtigerboy says:
will FFFg be fine enough.
Apr 25, 2010. 7:30 PMtigerboy says:
Would fine sand work?
Sep 15, 2007. 2:41 PMBeaters says:
Cutting off the sharp end eliminates sharp sticks falling from sky!
Apr 11, 2010. 1:32 PMPurple Guy says:
 Good point.......get it :P
Apr 11, 2010. 1:24 PMPurple Guy says:
 Could you use a potassium nitrate and sugar rocket mix instead of the black powder? I would think so but I'm not and expert at pyrotechnics :)
Aug 8, 2009. 7:22 AMroflmaourface says:
every thing is possible but the Black Powder....damn uk anti-fun regulations :(
Apr 11, 2010. 1:22 PMPurple Guy says:
 I agree with you there mate! you can't buy any decent supplies for pyrotechnics in shops and only a few sites will sell decent stuff and the P&P on that is terrible :(
Apr 4, 2010. 4:56 AMchemguy says:
No, it is there to direct the hot gases and flames from the rocket to provide thrust. It's a nozzle.
Apr 4, 2010. 4:55 AMchemguy says:
nice pencil lolol
Jul 3, 2009. 5:00 PMluvit says:
i filled a paper towel tube with black powder & have a yardstick for my skewer. i'm gonna go light it now.
Mar 27, 2010. 1:20 PMfire_drakon117 says:
i wanna video
Aug 26, 2009. 7:11 PMmo5 says:
u r a beast
Jul 6, 2009. 8:51 PMmax_bakerman says:
what exactly does the litter do?
Dec 7, 2009. 9:29 AMtrojanx says:
it works as a substitute for the clay found in most rocket type fireworks
Aug 17, 2009. 2:49 PMcfisher2727 says:
where do u get the black powder
Dec 7, 2009. 9:28 AMtrojanx says:
depends if you live in a state that allows the sale of black powder or not
if it is not illegal then some firework stores stock it
Oct 9, 2009. 3:48 PMclemsonguy1125 says:
 where did you get your fuse
Dec 7, 2009. 9:25 AMtrojanx says:
it is legal in some states to buy fuse most likely from any firework store will carry some sort of fuse if you cant find it near you check your local laws it may be illegal to make sell or use these where you live. IF its not illegal there are instructables on how to make a fuse.
Jun 16, 2009. 4:58 PMSk8erCk4Life says:
Is this a bottle rocket that goes up in the air because I bought like 100 of them and they only shot sparks out the top and didn't go up in the air? So you can use charcoal instead of gunpowder?
Dec 7, 2009. 9:22 AMtrojanx says:
bottle rockets always go up in the air you must have bought roman candles or sparklers...
Oct 23, 2009. 9:47 AMnorge says:
No, you can't use charcoal lol, but charcoal mixed with potasium nitrate and sulphur to make blackpowder/gunpowder.
Nov 8, 2009. 7:39 AMColonel88 says:
Oh the irony of using a fire dept. pencil.
Oct 25, 2009. 12:12 PMpyroboy99 says:
I cant get black powder is there anyway that i could possibly use some type of match powder with magesium powder for the lift?
1-40 of 227next »
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
8
Author:goawayndstay(Ukulele Rodeo)
