Homemade cheese and cider press
Here is how I built my own combination cider and cheese press. After a great apple harvest this year, I was inspired to obtain my own cider press. However, after pricing one and seeing that they cost exactly one arm and one leg to purchase I started thinking about building one myself. While no advanced rocket engineering degree is needed to understand the basics concept of apple cider making (apples+ pressure=cider), it took some thought as to how it all fits together. At the same time, I was interested in learning cheese making so I put a homemade cheese press on it as well. So, I looked at some other press variations online and in magazines and this is what I came up with.
I used white oak, because treated wood wasn't an option in a food application and soft woods such as pine can impart an aftertaste to the cider. The press part is just a scissors jack from the auto parts store mounted to one of the top timbers. At 3000 pounds, it should have enough ooomph to adequately press the apples. At the other end is a grinder, made up of two rollers I turned out of a piece of oak. I put stainless screws into it to use as teeth for mashing the apples. The ground apples fall into the slatted bucket, which is lined with a mesh bag and gets moved to the other end where the press is. The juice flows out the slats, and into the wooden trough, where it then heads out into the bucket.
The cheese press is just a wooden arm that's mounted across the two top timbers, with a second arm mounted to it that goes down into the cheese mold. A weight ( a jug with water in it) is hung from the end. The pressure is varied by adding or subtracting water from the jug.
And here's how I did it...
Step 1The future cider press
I started with some hearty oak timbers one fall day, purchased from a local sawmill...
41 comments
1-40 of 41next »
Jan 9, 2009. 4:57 PMaltomic says:
what about cleaning? would you hose it down? what about mold or wood rot? did you seal the wood in any way? e.g. olive oil nice instructable
Jan 23, 2012. 4:19 PMRiverBlackwood says:
Some Friends and I used a press this summer from around 50 years ago and the way it is kept clean is by hosing it down and allowing it to dry. We used it outside and it has no mold growing on it. As long as you clean it well just with water you should be good. It has no visible oils or anything on it, is very old, and very clean :) .
Feb 9, 2011. 8:58 PMDeanII says:
Your vegetable oils and olive oils may turn rancid and spoil the product. Mineral oil works the best and won't impart any taste. I make cutting boards and use a combination mineral oil and beeswax to keep them in great shape and looking good.
Jan 16, 2009. 6:33 PMBom6at says:
Great instructable! I remember reading somewhere that olive oil can "go bad" if used to seal woods. I don't know if this is true; but I always use mineral oil on my cutting board. Might be safer to stick with that.
Dec 29, 2011. 11:32 AMgodbacon says:
Hand crafted, not "homemade"
nice instruct able
Dec 27, 2011. 4:57 AMhague161 says:
Hi Your cider press looks about the same size as mine. How long did it take you to fully press out your apples? What did you use to pulp them with? Your press looks much nicer than mine. I just use a bottle jack for the pressure.
Sep 5, 2010. 11:33 AMntmoore says:
How has the galvanized held up? With Honey Extractors at least, its a big no-no, as the chemicals leach from the galvanizing (zinc?) into the honey.
Aug 30, 2010. 3:02 PMSenior Waffleman says:
coolio
Aug 30, 2010. 1:17 PMJohnSerthy says:
It seems a bit difficult but I am going to invite a friend over and see if we can do this
Aug 29, 2010. 1:38 PMSinAmos says:
I want to see this in action and what about cleaning it and pests?
Aug 26, 2010. 10:23 AMmheptonstall says:
What keeps the compression plate (under the jack) from hitting the bolt heads in the angle iron as it lowers into the basket? I'm looking into making a press but was going to skip the basket, but this looks like an easy way of making one!
Jul 29, 2010. 9:02 AMtheelectrifier says:
can you detail how you made the rollers each turn a different way?
Jan 25, 2010. 3:29 PMpablorox says:
How much would making this cost?
Sep 30, 2009. 12:00 PMLunarpancake says:
nice! but be careful dont expose the apple to too much metal or it will ruin your cider!
Sep 24, 2009. 7:58 AMCatheza says:
Last year I built my own cider mill cart that included my grinder (a stainless steel sink & 1 HP disposal unit, and a purchased fruit press, see photos of its construction at: http://wwww.flickr.com/photos/31423823@N08/ ). But I noticed that the ratchet-powered screw press was a bottle neck in my cider making. So this year, I'm building a new press incorporating a hydraulic press (bottle jack). I really like your approach to building a "basket". I also plan on using HDPE plastic cutting boards to separate my "cheeses". Last year, we invited family and friends to a couple of "cider making parties". It was so successful that I planted 6 cider apple trees (Ashmead's Kernel, Esopus Spitzenberg, Golden Russet, Harry Master's Jersey, Muscadet de Dieppe, & Newtown Pippin in our 24 tree mini-orchard in central Washington State. This year we look forward to more cider making parties, and enjoyng more sweet and hard cider. Ah, the fruitsof our labor!!!! LOL
Sep 29, 2009. 9:45 AMCatheza says:
First, cleaning our the disposal is relatively easy---if you do it immediately after the end of the last batch of apples. I first run mildly soapy, very hot water through to loosen any apple particles left inside, flush with plain hot water (runining the disposal during these phases, being very careful as to not get water near the electrical connections ( I run the power from a ground-fault interupter circuit) and then liberally flush the disposal out with a hose. I also clean up the cart and press in a similar manner. Second, we core the apples after washing and prior to grinding. We do this for three reasons; one, as you mention the seeds are bitter, two, it is difficult to wash out all the dirt and possible contaminents from the tops and bottoms of the apples, and three, we freeze and use the pressed "pommy' for cooking, streudel, etc. I have been using a ratchet press, but found it to be to slow and not able to press out a good % of the juice. And this weekend, I'm going to build my new press. Feel free to contact me directly at cal1advize@aol.com
Jul 10, 2009. 2:38 PMOrro says:
You could use it to make grape juice!!
Then you can make WINE!!!
Also the price of a wine press is 4 arms,6 torsoes , 3 legs and 2 heads.
Thanks
Orro
If I had 10c everytime people say that to me.
I'd have $47.40
Sep 13, 2009. 2:47 PMvernors says:
that can be arranged.......hehehehe
Jan 12, 2009. 4:18 PMawang8 says:
Wow! This is awesome! Althought I got one question. How much did this cost you in total?
Jan 22, 2009. 1:58 AMawang8 says:
About 85% cheaper than the bought versions...
If there was a bomb attack, then wouldn't the press catch on fire? If it's a atomic bomb or somethingand it doesn't burn you up, then maybe it'll turbo-react you up?
Sep 3, 2009. 11:07 AMspeedyspy2 says:
but there won't be a bomb attack with barack obama
May 27, 2009. 4:49 PMduotone says:
I think you did a great job! Good idea about the bike powering it Do you think an extra roller would help or is 2 fine? Would the rollers being at different heights help? So one roller would push the apple into the other roller. Would rollers spinning towards one another help to mash the apples up better?
Apr 13, 2009. 1:37 PMdjsc says:
That's awesome! I could never get the wood that cheap but there's some good ideas in there I might borrow. I've been thinking of making a printing press and driving it with bike parts.
Jan 31, 2009. 6:26 PM.connect.the.dots. says:
You're quite the engineer. Can this press also squeeze out oil from seeds, such as apricot seeds? If not, have you been thinking of making one that can?
Jan 12, 2009. 2:45 PMmmh says:
Very clever! So, when is the cheese making show? If the squirrels would stop erradicating my 5 in 1 antique apple tree I would have apples to press too.
Jan 11, 2009. 12:12 PMdrinkmorecoffee says:
Hey, that's Jeremy in step 4!
That's awesome. You should join my North Carolina group.
Are those bike parts from the BBI?
Jan 14, 2009. 1:12 AM1arrow24 says:
This is awsome, i've always wanted to make a cider press from the massive amount of apples i get given every year. A great instructable
Jan 13, 2009. 8:48 PMaristocob says:
Well done! I agree with your idea for a hopper. You might also benefit from a few more screws and perhaps if they wouldn't hit the opposite roller you could raise them up a bit too. Thanks for posting this Instructable and good luck!
Jan 7, 2009. 8:30 PMshaqcaliforniaman says:
Could probably make some good cider with those Wolf apples there
Jan 7, 2009. 4:46 AMdwitmer32 says:
Genius!
Jan 6, 2009. 12:51 PMjohnedscalf says:
Time for some apple-jack!
Dec 17, 2008. 5:54 PMgoogbar says:
Just plain... WONDERFUL!!! :) Loved it! Congrats. Gave you a 4.
Dec 17, 2008. 7:09 AMchuckr44 says:
On the rollers, what if you ground the screw heads to diamond shapes? That way the pointy corners would point in the direction of the roller turning, and help grind the apples.
Dec 16, 2008. 6:18 AMPKM says:
Wow.. cheese and cider, it's like the westcountry in food form :P If you made a lid for the apple box with a kind of V-shaped ridge on the bottom you could use that to press them into the whirling maw of death without committing a whole hopper full of apples. You might not even need the ridge, just a flat lid that could exert some weight on the apples would do. I like your cunning chain mechanism for turning the rollers... and for some reason the phrase "hearty oak timbers" as well.
1-40 of 41next »
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
53
Author:bwitmer
