Homemade cheese and cider press by bwitmer
Contest WinnerFeatured
Here is how I built my own combination cider and cheese press. After a great apple harvest this year, I was inspired to obtain my own cider press. However, after pricing one and seeing that they cost exactly one arm and one leg to purchase I started thinking about building one myself. While no advanced rocket engineering degree is needed to understand the basics concept of apple cider making (apples+ pressure=cider), it took some thought as to how it all fits together. At the same time, I was interested in learning cheese making so I put a homemade cheese press on it as well. So, I looked at some other press variations online and in magazines and this is what I came up with.
I used white oak, because treated wood wasn't an option in a food application and soft woods such as pine can impart an aftertaste to the cider. The press part is just a scissors jack from the auto parts store mounted to one of the top timbers. At 3000 pounds, it should have enough ooomph to adequately press the apples. At the other end is a grinder, made up of two rollers I turned out of a piece of oak. I put stainless screws into it to use as teeth for mashing the apples. The ground apples fall into the slatted bucket, which is lined with a mesh bag and gets moved to the other end where the press is. The juice flows out the slats, and into the wooden trough, where it then heads out into the bucket.
The cheese press is just a wooden arm that's mounted across the two top timbers, with a second arm mounted to it that goes down into the cheese mold. A weight ( a jug with water in it) is hung from the end. The pressure is varied by adding or subtracting water from the jug.
And here's how I did it...
Step 1: The future cider press
I started with some hearty oak timbers one fall day, purchased from a local sawmill...
sdaupanner says: Oct 5, 2012. 11:19 AM
Nice Job but I was wondering if cutti ng the apples in half or maybe into Quarters might help. Also did the oak clean up OK after you finished and did you have any flavor from the oak??? MAPLE is the wood to use around food processes it is tight grained so it helps fight Bacteria. That is why there are very few Butchers Blocks made of OAK it is maple that they use.
cube-convict says: Aug 15, 2012. 3:42 PM
I agree, the galvanized seems iffy. No reason you can't use steel. It will rust, but a little iron in your cider won't hurt! or you can build a mash bin by putting a band around the outside.
alan_of_springcanyon says: Mar 29, 2012. 8:52 AM
Your work is absolutely lovely.
I noticed there were a few comments about putting galvanized metals near food products; I would fourth that, including copper, and I would also separate the cheese processing from the yeast based processing (cider, wine, etc.) for bacteriological reasons.
Stainless is the way to go for collecting fluids, or even plastic, in conjunction with your wood. Wood in conjunction with chlorine cleaners can enable the agents that create trichloroanisole (TCA) which is NOT good eats in wine - it also creates the flavor profile commonly called "corked".
So cleaning wise, you must be careful unless you are after your own personalized microbial flora/fauna.
A very good cleaner for wine and cider (and beer) areas is "eco-bleach" sold in grocery stores as a non-chlorine bleach, containing citric acid and hydrogen peroxide. Wonderful stuff - sterilizer and cleaner.
We clean big wine tanks (stainless, mostly but plastic too) by starting with sodium percarbonate (available in beer and wine brewing stores) and then neutralizing the slight causticity of the percarbonate with citric acid (as in the bleach alternative). Now you know the secrets of big winery cleaning!
Seriously, I love your craftsmanship.
altomic says: Jan 9, 2009. 4:57 PM
what about cleaning? would you hose it down? what about mold or wood rot? did you seal the wood in any way? e.g. olive oil nice instructable
RiverBlackwood says: Jan 23, 2012. 4:19 PM
Some Friends and I used a press this summer from around 50 years ago and the way it is kept clean is by hosing it down and allowing it to dry. We used it outside and it has no mold growing on it. As long as you clean it well just with water you should be good. It has no visible oils or anything on it, is very old, and very clean :) .
bwitmer (author) says: Jan 14, 2009. 4:23 PM
I'm definitely not a wood expert, but from what I've read white oak is pretty good at being mold/rot resistant. I found some food safe gel for sealing wood that I'm going to apply to the press that should protect it- it's called EZ-DO by the John Boos company(I got mine online from Cutlery and More). They also make the food-safe oil for cutting boards that would also work. I'll probably wash it good with soap and water, and then seal it with the EZ-DO. One suggestion that I've read is to sterilize it before use by pouring boiling water on it , or at least wash it with soap and water. Then, reseal it at the end of the season. I think that any oil, such as olive would work, it would just be a matter of finding one that didn't change the flavor of the cider. I've heard that mineral oil works well, and is cheap. Thanks for checking it out!
DeanII says: Feb 9, 2011. 8:58 PM
Your vegetable oils and olive oils may turn rancid and spoil the product. Mineral oil works the best and won't impart any taste. I make cutting boards and use a combination mineral oil and beeswax to keep them in great shape and looking good.
Bom6at says: Jan 16, 2009. 6:33 PM
Great instructable! I remember reading somewhere that olive oil can "go bad" if used to seal woods. I don't know if this is true; but I always use mineral oil on my cutting board. Might be safer to stick with that.
godbacon says: Dec 29, 2011. 11:32 AM
Hand crafted, not "homemade"
nice instruct able
hague161 says: Dec 27, 2011. 4:57 AM
Hi Your cider press looks about the same size as mine. How long did it take you to fully press out your apples? What did you use to pulp them with? Your press looks much nicer than mine. I just use a bottle jack for the pressure.
ntmoore says: Sep 5, 2010. 11:33 AM
How has the galvanized held up? With Honey Extractors at least, its a big no-no, as the chemicals leach from the galvanizing (zinc?) into the honey.
Senior Waffleman says: Aug 30, 2010. 3:02 PM
coolio
JohnSerthy says: Aug 30, 2010. 1:17 PM
It seems a bit difficult but I am going to invite a friend over and see if we can do this
SinAmos says: Aug 29, 2010. 1:38 PM
I want to see this in action and what about cleaning it and pests?
mheptonstall says: Aug 26, 2010. 10:23 AM
What keeps the compression plate (under the jack) from hitting the bolt heads in the angle iron as it lowers into the basket? I'm looking into making a press but was going to skip the basket, but this looks like an easy way of making one!
theelectrifier says: Jul 29, 2010. 9:02 AM
can you detail how you made the rollers each turn a different way?
bwitmer (author) says: Aug 1, 2010. 1:56 PM
Hi- it's hard to explain, but if you look closely at the picture in step 14 you can see how I routed the chain around the gear on the main crank, and then ran it under the next gear, with the tensioner keeping it taut. So, when the main crank is turned the chain makes the next gear run in the opposite direction. I hope that helps...
pablorox says: Jan 25, 2010. 3:29 PM
How much would making this cost?
Lunarpancake says: Sep 30, 2009. 12:00 PM
nice! but be careful dont expose the apple to too much metal or it will ruin your cider!
Catheza says: Sep 24, 2009. 7:58 AM
Last year I built my own cider mill cart that included my grinder (a stainless steel sink & 1 HP disposal unit, and a purchased fruit press, see photos of its construction at: http://wwww.flickr.com/photos/31423823@N08/ ). But I noticed that the ratchet-powered screw press was a bottle neck in my cider making. So this year, I'm building a new press incorporating a hydraulic press (bottle jack). I really like your approach to building a "basket". I also plan on using HDPE plastic cutting boards to separate my "cheeses". Last year, we invited family and friends to a couple of "cider making parties". It was so successful that I planted 6 cider apple trees (Ashmead's Kernel, Esopus Spitzenberg, Golden Russet, Harry Master's Jersey, Muscadet de Dieppe, & Newtown Pippin in our 24 tree mini-orchard in central Washington State. This year we look forward to more cider making parties, and enjoyng more sweet and hard cider. Ah, the fruitsof our labor!!!! LOL
bwitmer (author) says: Sep 29, 2009. 6:36 AM
Very nice! How did the sink/disposal unit work? Do you have to clean out the disposal after using it, and is that hard? Also, I had read on another site where someone who had used a disposal unit claimed that the apples had to be cored before grinding w/ a disposal to remove the seeds. I think he was worried that grinding the seeds that fine might make the cider bitter...did you have to do that? Glad that you had success.
Catheza says: Sep 29, 2009. 9:45 AM
First, cleaning our the disposal is relatively easy---if you do it immediately after the end of the last batch of apples. I first run mildly soapy, very hot water through to loosen any apple particles left inside, flush with plain hot water (runining the disposal during these phases, being very careful as to not get water near the electrical connections ( I run the power from a ground-fault interupter circuit) and then liberally flush the disposal out with a hose. I also clean up the cart and press in a similar manner. Second, we core the apples after washing and prior to grinding. We do this for three reasons; one, as you mention the seeds are bitter, two, it is difficult to wash out all the dirt and possible contaminents from the tops and bottoms of the apples, and three, we freeze and use the pressed "pommy' for cooking, streudel, etc. I have been using a ratchet press, but found it to be to slow and not able to press out a good % of the juice. And this weekend, I'm going to build my new press. Feel free to contact me directly at cal1advize@aol.com
Orro says: Jul 10, 2009. 2:38 PM
You could use it to make grape juice!!
Then you can make WINE!!!
Also the price of a wine press is 4 arms,6 torsoes , 3 legs and 2 heads.
Thanks
Orro
If I had 10c everytime people say that to me.
I'd have $47.40
vernors says: Sep 13, 2009. 2:47 PM
that can be arranged.......hehehehe
awang8 says: Jan 12, 2009. 4:18 PM
Wow! This is awesome! Althought I got one question. How much did this cost you in total?
bwitmer (author) says: Jan 14, 2009. 4:33 PM
Ummm...It came out to around $130-$140 or so. The wood was from a local sawmill and cost around $60, the jack was $20, the stainless screws $20, another $25 for misc. bolts, screws etc., and then $10 or so in miscellaneous parts( I think that gets it all, though I might be forgetting something).. To buy them you're getting up into the $800-$1000 range, so it came out significantly cheaper. And, in the case of a bomb attack gives you something really heavy to crawl under with the oak timbers.
awang8 says: Jan 22, 2009. 1:58 AM
About 85% cheaper than the bought versions...
If there was a bomb attack, then wouldn't the press catch on fire? If it's a atomic bomb or somethingand it doesn't burn you up, then maybe it'll turbo-react you up?
speedyspy2 says: Sep 3, 2009. 11:07 AM
but there won't be a bomb attack with barack obama
duotone says: May 27, 2009. 4:49 PM
I think you did a great job! Good idea about the bike powering it Do you think an extra roller would help or is 2 fine? Would the rollers being at different heights help? So one roller would push the apple into the other roller. Would rollers spinning towards one another help to mash the apples up better?
djsc says: Apr 13, 2009. 1:37 PM
That's awesome! I could never get the wood that cheap but there's some good ideas in there I might borrow. I've been thinking of making a printing press and driving it with bike parts.
.connect.the.dots. says: Jan 31, 2009. 6:26 PM
You're quite the engineer. Can this press also squeeze out oil from seeds, such as apricot seeds? If not, have you been thinking of making one that can?
mmh says: Jan 12, 2009. 2:45 PM
Very clever! So, when is the cheese making show? If the squirrels would stop erradicating my 5 in 1 antique apple tree I would have apples to press too.
bwitmer (author) says: Jan 14, 2009. 4:34 PM
5 in 1- awesome!
drinkmorecoffee says: Jan 11, 2009. 12:12 PM
Hey, that's Jeremy in step 4!
That's awesome. You should join my North Carolina group.
Are those bike parts from the BBI?
bwitmer (author) says: Jan 14, 2009. 4:25 PM
Yes, and yes! That is Mr. Ferrell himself, looking stylish on the drill press, and the bike parts were donated by the good folks at the Boone Bike Initiative. I'll check your group out- thanks for the invite.
1arrow24 says: Jan 14, 2009. 1:12 AM
This is awsome, i've always wanted to make a cider press from the massive amount of apples i get given every year. A great instructable
aristocob says: Jan 13, 2009. 8:48 PM
Well done! I agree with your idea for a hopper. You might also benefit from a few more screws and perhaps if they wouldn't hit the opposite roller you could raise them up a bit too. Thanks for posting this Instructable and good luck!
shaqcaliforniaman says: Jan 7, 2009. 8:30 PM
Could probably make some good cider with those Wolf apples there
dwitmer32 says: Jan 7, 2009. 4:46 AM
Genius!
johnedscalf says: Jan 6, 2009. 12:51 PM
Time for some apple-jack!
pudicobar says: Dec 17, 2008. 5:54 PM
Just plain... WONDERFUL!!! :) Loved it! Congrats. Gave you a 4.
chuckr44 says: Dec 17, 2008. 7:09 AM
On the rollers, what if you ground the screw heads to diamond shapes? That way the pointy corners would point in the direction of the roller turning, and help grind the apples.
PKM says: Dec 16, 2008. 6:18 AM
Wow.. cheese and cider, it's like the westcountry in food form :P If you made a lid for the apple box with a kind of V-shaped ridge on the bottom you could use that to press them into the whirling maw of death without committing a whole hopper full of apples. You might not even need the ridge, just a flat lid that could exert some weight on the apples would do. I like your cunning chain mechanism for turning the rollers... and for some reason the phrase "hearty oak timbers" as well.
gmjhowe says: Dec 16, 2008. 5:27 AM
Nice work! i love the apple mincing shot, you should get a video uploaded!
Pro
Get More Out of Instructables
Already have an Account?
close
PDF Downloads
Upgrade to Pro today!
