I used white oak, because treated wood wasn't an option in a food application and soft woods such as pine can impart an aftertaste to the cider. The press part is just a scissors jack from the auto parts store mounted to one of the top timbers. At 3000 pounds, it should have enough ooomph to adequately press the apples. At the other end is a grinder, made up of two rollers I turned out of a piece of oak. I put stainless screws into it to use as teeth for mashing the apples. The ground apples fall into the slatted bucket, which is lined with a mesh bag and gets moved to the other end where the press is. The juice flows out the slats, and into the wooden trough, where it then heads out into the bucket.
The cheese press is just a wooden arm that's mounted across the two top timbers, with a second arm mounted to it that goes down into the cheese mold. A weight ( a jug with water in it) is hung from the end. The pressure is varied by adding or subtracting water from the jug.
And here's how I did it...
Remove these ads by
Signing UpStep 1The future cider press
I noticed there were a few comments about putting galvanized metals near food products; I would fourth that, including copper, and I would also separate the cheese processing from the yeast based processing (cider, wine, etc.) for bacteriological reasons.
Stainless is the way to go for collecting fluids, or even plastic, in conjunction with your wood. Wood in conjunction with chlorine cleaners can enable the agents that create trichloroanisole (TCA) which is NOT good eats in wine - it also creates the flavor profile commonly called "corked".
So cleaning wise, you must be careful unless you are after your own personalized microbial flora/fauna.
A very good cleaner for wine and cider (and beer) areas is "eco-bleach" sold in grocery stores as a non-chlorine bleach, containing citric acid and hydrogen peroxide. Wonderful stuff - sterilizer and cleaner.
We clean big wine tanks (stainless, mostly but plastic too) by starting with sodium percarbonate (available in beer and wine brewing stores) and then neutralizing the slight causticity of the percarbonate with citric acid (as in the bleach alternative). Now you know the secrets of big winery cleaning!
Seriously, I love your craftsmanship.
nice instruct able
Then you can make WINE!!!
Also the price of a wine press is 4 arms,6 torsoes , 3 legs and 2 heads.
Thanks
Orro
If I had 10c everytime people say that to me.
I'd have $47.40
If there was a bomb attack, then wouldn't the press catch on fire? If it's a atomic bomb or somethingand it doesn't burn you up, then maybe it'll turbo-react you up?
That's awesome. You should join my North Carolina group.
Are those bike parts from the BBI?
