When taking my junk-picked 70s-era lawnmower apart, besides finding out that this motor was made the same year I was, I realized that the exhaust threads are a standard pitch 1/2 inch pipe thread!
The parts you will need are:
A short 1/2 inch nipple (short pipe, threaded on both ends)
A 1/2 inch x 1 inch hex bushing (female 1/2 inch on one end, male 1 inch on the other)
A 1 inch 90 degree elbow
A length of 1 inch pipe
A 1 inch cap
A drill and small drill bit(s)
Cutting oil for drilling (WD-40 or even motor oil will probably work)
(optional) Pieces of fiberglass tape or cloth for sound-deadening material.
PLEASE use black gas piping, NOT galvanized pipe. Galvanized pipe is coated inside and out in zinc. Zinc heated to very high temperatures can offgas and make you feel very sick. There is some debate as to whether zinc exposure leads to long term health effects, but I have gotten some stern warnings against welding zinc, so have used only black gas piping for this project.
You could also probably do this project with aluminum or threaded copper pipe, but for safety and affordability, I went with the steel. You probably wouldn't want to use soldered copper, in case the solder were to melt and cause trouble.
Remove these ads by
Signing UpStep 1Remove old muffler
On the plus side, it looks cool, especially with the chrome cover.! LOL!
Secondly, you are again being incredibly offensive by, effectively, calling the builder a moron incapable of foresight or any knowledge of safety. For all you know, this gentleman is an engineer who designs two-stroke engines for NASA, or some other type of engineering hyper-genius. Both of your posts are insulting and degrading to the gentleman who wrote this article and I am, again, deeply offended by your treatment of someone who took time out of his life to share his experience and ingenuity and bring a smile to people's faces. So, because of your condescending posts, I'll respond in kind.
"You know something, I really don't care what anybody builds here."
"I don't care what anybody builds here..."
- Then why did you bother to comment in the first place?
"All I tried to do is make sure the builder is being careful to make sure he isn't hurt, maimed, or killed."
- Via a text post, after the fact, online, anonymously, with alleged "facts" of things that are so improbable it's insulting? Also, this contradicts your previous statement that you "care what anybody builds here". Has the Nobel committee been made aware of you?
"but please be careful and when things go wrong, take responsibility for any negligence on your part.."
- LOL. What?
"Spark arresting features of this system probably will not meet US Dept. of Forestry specs."
- Please submit a detailed diagram of exact blue-prints of the builder's design and highlight the specific faults you have found. Also, please post the specific and applicable "US Dept. of Forestry specs" along with exactly how they affect this build. Please cite your sources.
"Every year someone modifies a lawnmower in a way that causes them pain or death."
- Please list specific examples of both death and injury each year starting from the invention of the lawn mower by Edwin Beard Budding in 1827. Please cite your sources.
"I have seen pipe systems like this before and the weight of the pipe usually wears out the threads in the engine because you cannot keep them tight."
- Please cite each and every specific instance you have personally had direct experience with. Please note dates, locations, and potential witnesses. Also, please post the exact weight of the exhaust system the builder implemented, along with equations to prove your hypothesis. Please show the exact torque at the fulcrum and detail the exact tolerances of the materials and threads on both the engine block and the exhaust system. Please cite your sources.
"5. Bigger exhaust system = more possibility of skin burns or setting dried grass on fire."
- Please explain how. The chrome tip on the exhaust will actually act as a heat shield as there is minimal contact with the muffler, and the exhaust is not venting openly, but inside the tube of the exhaust tip which would act as a crude flame arrestor along with the fibreglass inside. Plus, the muffler is pointing forward, away from the operator position, which would severely diminish the likelihood of ever coming in direct physical contact with it. Also, note the builder's own writing, "Dress up your exhaust tube and add a margin of safety with an exhaust tip or cover".
"6. The cost of the pipe and fittings is way more than the $2-3 for an approved muffler."
- Please cite examples. Lawnmower mufflers can cost up-wards of $11 or more (http://www.amazon.com/b?ie=UTF8&node=155375011). Please list for us the exact model number of the specific "approved muffler" for this engine, along with a website showing an average price a consumer could expect to pay in USD. Please cite your sources.
"1. This idea needs to have the amount of back-pressure figured out so you don't burn the valves or cause power loss."
- How do you know the builder did not? He, in fact, states quite clearly that, "I drilled 5 3/16 inch holes. I discovered that two holes was not enough and 5 seemed to be OK". Please list the exact exhaust pressure for this specific model of engine, taking into account it's exact current age and operating condition. Please also note what the optimal operating exhaust pressure range should be, taking into account weather and other operating conditions, and an equation showing exactly how to calibrate a custom muffler to operate within these specs. Please also note the exact amount of back-pressure created by the current exhaust system and note whether or not it is operating within acceptable tolerances and, if it is not, how to modify it to bring within the optimal operating specs. Please cite your sources.
Please also list any degrees, certifications, qualifications, and/or training you have that make you qualified to provide criticism on this project, including your practical experience with federal regulations. Please cite your sources, examples, and proof of above.
In the future, you may want to try acting like less of a buzz-kill and just enjoy things. You don't need to be condescending, rude, confrontational, or even just plain mean to get attention or start a conversation. Perhaps a better way of approaching the matter would have been to ask, "Hey, have you had any problems with the back-pressure or it flaring up on you". That would have brought his attention to your concerns, over what you perceive to be a death-trap, in a neutral, non-confrontational, and almost friendly way. Then it leaves the door open for him to say if he has had the problems and, if so, how he resolved them, or to note that he hasn't and won't have the problems because he took things into account.
Something to keep in mind is that most of us who tinker around with these, and more potentially dangerous projects, are most usually pretty darn aware of not only the physics and chemistry of what we're playing with, but the safety precautions as well. This project is about as far from dangerous as one can get without using Play-Do, yarn and blunt-tipped scissors. The engine is so under-powered that even if he had completely plugged the exhaust, nothing more dangerous would likely have happened except the engine dying.
Of exhaustion. *rimshot*
You could have handled this all much better and in a far nicer way. You could have at least approached this in a manner that didn't involve insulting people and coming off as such a condescending, arrogant, and mean person. I'm not saying that you are any of these things, just that you are coming off as such. You could have just been social and human.
Perhaps this can all end here, as I know that I won't bother responding to any further posts here. This is the end of my fun and it's going to just get dumb after this. I really can't believe that you are so oblivious about your behaviour, but perhaps you will keep it all in mind next time you post a comment to a project someone posts and is obviously proud of. Tearing people down is not the way to get positive attention. In the end, however, there's certainly nothing more for you to say as I've really kind of put you in a corner. So let it drop and walk away or you're going to look silly. This isn't a fight, so just be human and social.
Good luck in your future endeavours. I really do mean that.
I love this site and come here all the time. Why I looked anywhere else for a homemade muffler ... I don't know. :)
What would be a suitable "stuffing" to pack into an old small engine muffler? Steel wool, fiberglass insulation? Any suggestions are welcome!
The way they 'glass pack' mufflers in an automotive exhaust is just to fill an outside cavity with glass with a straight open tube through the middle of the glass. This is not how I did it, and it didn't work so well.
search images.google.com for 'glasspack' to see what I described above.
