3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Homemade exhaust for your old lawnmower
You can build your own, homemade exhaust system for an old Briggs and Stratton lawnmower engine!
When taking my junk-picked 70s-era lawnmower apart, besides finding out that this motor was made the same year I was, I realized that the exhaust threads are a standard pitch 1/2 inch pipe thread!
The parts you will need are:
A short 1/2 inch nipple (short pipe, threaded on both ends)
A 1/2 inch x 1 inch hex bushing (female 1/2 inch on one end, male 1 inch on the other)
A 1 inch 90 degree elbow
A length of 1 inch pipe
A 1 inch cap
A drill and small drill bit(s)
Cutting oil for drilling (WD-40 or even motor oil will probably work)
(optional) Pieces of fiberglass tape or cloth for sound-deadening material.
PLEASE use black gas piping, NOT galvanized pipe. Galvanized pipe is coated inside and out in zinc. Zinc heated to very high temperatures can offgas and make you feel very sick. There is some debate as to whether zinc exposure leads to long term health effects, but I have gotten some stern warnings against welding zinc, so have used only black gas piping for this project.
You could also probably do this project with aluminum or threaded copper pipe, but for safety and affordability, I went with the steel. You probably wouldn't want to use soldered copper, in case the solder were to melt and cause trouble.
Step 1Remove old muffler
Remove old muffler
On these old engines, the muffler is easy enough to remove. Simply unscrew it from the engine block. (lefty loosey, and please do this when the muffler is cold!)
74 comments
1-40 of 74next »
Nov 7, 2011. 12:33 PMjulianjim says:
I just found this site after looking "how to r&r B&S carb."! I saw the article on making a new muffler and think it was great. That poor guy that was a "killjoy", just needs some toys to play with? Now I'm thinking how would my 16.5HP Craftsman riding mower look with "trucker pipes"? I live in the mountians of San Diego, and sound does travel!! Mostly chainsaws. We had our first snow this past friday, which means for us a long winter, so I'll be looking at this great site more often! Keep up the great ideas, julianjim.
Jul 5, 2011. 11:42 AMELITE-01 says:
Nice one, I'll try something like this on my go kart
Mar 4, 2011. 11:06 PMmpandersen says:
Good article, I would recommend Automatic Transmission Fluid (ATF) as a cutting lubricant, you should have some lying around ...
Sep 12, 2010. 7:58 PMhifatpeople says:
heres an idea, make the muffler look like a machine gun barrel.
Sep 12, 2010. 7:28 PMFatFuck says:
We all know this muffler looks pretty cool, but there's a down fall to this. The shaking of the engine will cause pieces to loosen, letting exhaust escape in the cracks, causing the engine to lose some power. I did the same thing (sort of) with my racing lawn mower(made it sound like a quad), and had to take it off and put it back together with heat resistant sealant. Nice muffler though.
Jun 30, 2010. 10:34 AMJunkyard Dawg says:
Man, that exaust makes the lawn mower look like a hot-rod. If (and when) you re-paint it, can I suggest a hot-rod type flame job? I got to try this for my mower. It's newer, but it will look better with something like that on it. Almost like the NASCAR exaust system.
Jul 1, 2010. 9:40 PMcambigfoot says:
put a nos system too??? lol :)
Jul 2, 2010. 12:54 PMJunkyard Dawg says:
I wouldn't take it that far, but I may consider puting a big-block V-8 on it. Immagine the drag-races the thing would win... =)
Jul 2, 2010. 1:11 PMJunkyard Dawg says:
Accually, no to the big-block V-8. How about a NASA type solid-rocket booster? (man, the lawn would be mowed in 1.2 seccondswith a V-8 alone, never mind the fact it will be done in the blink of an eye with rocket fuel.)
Aug 28, 2008. 12:12 PMsegcd says:
OK, I see some problems here. 1. This idea needs to have the amount of backpressure figured out so you don't burn the valves or cause power loss. 2. I have seen pipe systems like this before and the weight of the pipe usually wears out the threads in the engine because you cannot keep them tight. 3. Spark arresting features of this system probably will not meet US Dept. of Forestry specs. 4. Might be more dangerous if fuel is spilled on the mower. 5. Bigger exhaust system = more possibility of skin burns or setting dried grass on fire. 6. The cost of the pipe and fittings is way more than the $2-3 for an approved muffler.
On the plus side, it looks cool, especially with the chrome cover.! LOL!
Apr 15, 2010. 1:02 AMViqilance says:
I want you body....
Jul 26, 2009. 12:11 PMKaptain krunch says:
No one cares about safety, seriously, there are many more dangerous things than a funkin lawn mower muffler. Second, with a 4 stroke you dont need backpressure, as long as you have some sort of pipe longer than a few inches you WILL NOT burn out your exhaust valve, and there is no way to lose power by not having back pressure on a 4 stroke. gas evaporates fast enough, that if you spilled a bit on the muffler, by the time it got hot enough to ignite gas, all the gas would be gone.
Feb 27, 2009. 8:18 AMmaize5 says:
First things first. You're a killjoy, and if you're so worried about obscure, irrelevant and stupid regulations and rules, then what are you doing on this website? I'm really quite serious. I know I read three articles on bomb-making and two about lockpicking before breakfast. 1. The brilliant thing with projects like this is the overkill. Drill more than enough holes and it won't cause any back pressure. 2. So far as the stripping or cross-threading is concerned, the man even suggests supporting the weight somehow. Also, it's a thirty-year-old law mower, what does it matter if it does strip? He can take the entire muffler off and have a SUPER loud lawnmower just for the heck of it. 3. Who cares? 4. Oh, wow... My lawnmower is on fire. Hold on while I call a few people to come over and watch and maybe bring some thermite so we can do this right. 5. Oops. I burned myself on an exhaust. Again. I'm tattooed up both arms and legs from exhausts from motorcycles and cars and ovens and god-knows what else. Go somewhere else if you're going to live in fear of life. Some of us do things with the full expectation of getting hurt. It's half the fun to have a scar to associate with something really fun or really stupid your did. Most times both. 6. Did he ever mention this was going to be a money-saving endeavor? The whole point of this is that the stock muffler wasn't quiet enough for this man's liking, so he built a bigger one and put a chrome tip on it. Just because he could. Welcome to America, a country founded upon the principal of experimentation, the Rule of Cool, and getting away from killjoys. I, for one, would try to make an exhaust cover like they put on the AC Cobra's side pipes, or maybe built a mini diesel smoke stack just to make it look cooler. I bet with a little welding and some pre-planning, you could give your lawnmower twice-pipes. I'd absolutely love to try this on a gas-powered rotary mower, just for the look. Maybe even vent the exhaust to the side, and put a spark plug in it hooked to a battery. Nothing says "Good mornin'!" like flaming exhaust when you're mowing the lawn. Maybe you could even vent it straight up and brace it, so everyone can enjoy the flames.
May 23, 2011. 3:58 AMlukeyj15 says:
Amen.
May 10, 2009. 5:53 PMDanish M1Garand says:
Hell YEAH!
Feb 27, 2009. 10:32 AMsegcd says:
You know something, I really don't care what anybody builds here. All I tried to do is make sure the builder is being careful to make sure he isn't hurt, maimed, or killed. If any of the three happened to the builder, I'm sure it would kill somebody's joy in a hurry. Let's not call people names and criticize why they are here. Every year someone modifies a lawnmower in a way that causes them pain or death. The next thing that happens is that the manufacturer and the dealer get sued. I don't care what anybody builds here but please be careful and when things go wrong, take responsibility for any negligence on your part..
Feb 28, 2009. 12:06 PMmaize5 says:
Firstly, nobody called you a name. Calling you a killjoy is no more calling names than saying that someone who runs professionally or competitively is a runner.
Secondly, you are again being incredibly offensive by, effectively, calling the builder a moron incapable of foresight or any knowledge of safety. For all you know, this gentleman is an engineer who designs two-stroke engines for NASA, or some other type of engineering hyper-genius. Both of your posts are insulting and degrading to the gentleman who wrote this article and I am, again, deeply offended by your treatment of someone who took time out of his life to share his experience and ingenuity and bring a smile to people's faces. So, because of your condescending posts, I'll respond in kind.
"You know something, I really don't care what anybody builds here."
"I don't care what anybody builds here..."
- Then why did you bother to comment in the first place?
"All I tried to do is make sure the builder is being careful to make sure he isn't hurt, maimed, or killed."
- Via a text post, after the fact, online, anonymously, with alleged "facts" of things that are so improbable it's insulting? Also, this contradicts your previous statement that you "care what anybody builds here". Has the Nobel committee been made aware of you?
"but please be careful and when things go wrong, take responsibility for any negligence on your part.."
- LOL. What?
"Spark arresting features of this system probably will not meet US Dept. of Forestry specs."
- Please submit a detailed diagram of exact blue-prints of the builder's design and highlight the specific faults you have found. Also, please post the specific and applicable "US Dept. of Forestry specs" along with exactly how they affect this build. Please cite your sources.
"Every year someone modifies a lawnmower in a way that causes them pain or death."
- Please list specific examples of both death and injury each year starting from the invention of the lawn mower by Edwin Beard Budding in 1827. Please cite your sources.
"I have seen pipe systems like this before and the weight of the pipe usually wears out the threads in the engine because you cannot keep them tight."
- Please cite each and every specific instance you have personally had direct experience with. Please note dates, locations, and potential witnesses. Also, please post the exact weight of the exhaust system the builder implemented, along with equations to prove your hypothesis. Please show the exact torque at the fulcrum and detail the exact tolerances of the materials and threads on both the engine block and the exhaust system. Please cite your sources.
"5. Bigger exhaust system = more possibility of skin burns or setting dried grass on fire."
- Please explain how. The chrome tip on the exhaust will actually act as a heat shield as there is minimal contact with the muffler, and the exhaust is not venting openly, but inside the tube of the exhaust tip which would act as a crude flame arrestor along with the fibreglass inside. Plus, the muffler is pointing forward, away from the operator position, which would severely diminish the likelihood of ever coming in direct physical contact with it. Also, note the builder's own writing, "Dress up your exhaust tube and add a margin of safety with an exhaust tip or cover".
"6. The cost of the pipe and fittings is way more than the $2-3 for an approved muffler."
- Please cite examples. Lawnmower mufflers can cost up-wards of $11 or more (http://www.amazon.com/b?ie=UTF8&node=155375011). Please list for us the exact model number of the specific "approved muffler" for this engine, along with a website showing an average price a consumer could expect to pay in USD. Please cite your sources.
"1. This idea needs to have the amount of back-pressure figured out so you don't burn the valves or cause power loss."
- How do you know the builder did not? He, in fact, states quite clearly that, "I drilled 5 3/16 inch holes. I discovered that two holes was not enough and 5 seemed to be OK". Please list the exact exhaust pressure for this specific model of engine, taking into account it's exact current age and operating condition. Please also note what the optimal operating exhaust pressure range should be, taking into account weather and other operating conditions, and an equation showing exactly how to calibrate a custom muffler to operate within these specs. Please also note the exact amount of back-pressure created by the current exhaust system and note whether or not it is operating within acceptable tolerances and, if it is not, how to modify it to bring within the optimal operating specs. Please cite your sources.
Please also list any degrees, certifications, qualifications, and/or training you have that make you qualified to provide criticism on this project, including your practical experience with federal regulations. Please cite your sources, examples, and proof of above.
In the future, you may want to try acting like less of a buzz-kill and just enjoy things. You don't need to be condescending, rude, confrontational, or even just plain mean to get attention or start a conversation. Perhaps a better way of approaching the matter would have been to ask, "Hey, have you had any problems with the back-pressure or it flaring up on you". That would have brought his attention to your concerns, over what you perceive to be a death-trap, in a neutral, non-confrontational, and almost friendly way. Then it leaves the door open for him to say if he has had the problems and, if so, how he resolved them, or to note that he hasn't and won't have the problems because he took things into account.
Something to keep in mind is that most of us who tinker around with these, and more potentially dangerous projects, are most usually pretty darn aware of not only the physics and chemistry of what we're playing with, but the safety precautions as well. This project is about as far from dangerous as one can get without using Play-Do, yarn and blunt-tipped scissors. The engine is so under-powered that even if he had completely plugged the exhaust, nothing more dangerous would likely have happened except the engine dying.
Of exhaustion. *rimshot*
You could have handled this all much better and in a far nicer way. You could have at least approached this in a manner that didn't involve insulting people and coming off as such a condescending, arrogant, and mean person. I'm not saying that you are any of these things, just that you are coming off as such. You could have just been social and human.
Perhaps this can all end here, as I know that I won't bother responding to any further posts here. This is the end of my fun and it's going to just get dumb after this. I really can't believe that you are so oblivious about your behaviour, but perhaps you will keep it all in mind next time you post a comment to a project someone posts and is obviously proud of. Tearing people down is not the way to get positive attention. In the end, however, there's certainly nothing more for you to say as I've really kind of put you in a corner. So let it drop and walk away or you're going to look silly. This isn't a fight, so just be human and social.
Good luck in your future endeavours. I really do mean that.
Jan 16, 2010. 6:28 PMWaste Of Space says:
        Thanks for the laugh, that was really funny.
Jan 22, 2010. 1:18 PMmaize5 says:
I'm actually a little upset that nobody has specifically made a comment on my joke about the engine dying of exhaustion. I really thought that was funny.
Mar 1, 2009. 5:07 AMbigredlevy says:
point of order, Mr speaker, relevance. come on lads, it looks good, that's all that counts. didn't your mother's ever teach you that if you don't have anything nice to say, then don't bother commenting on other blokes instructables.
Mar 10, 2010. 5:22 PMsabre says:
i agree... you might be crazy! =)
Feb 13, 2010. 1:07 AMhjartland says:
Wow that is a lot of reading ( re: comments )
I love this site and come here all the time. Why I looked anywhere else for a homemade muffler ... I don't know. :)
What would be a suitable "stuffing" to pack into an old small engine muffler? Steel wool, fiberglass insulation? Any suggestions are welcome!
Feb 25, 2010. 6:09 AMRahdzhillaxxx says:
Round my place you wait long enough and the mice will pack it for you.  and then if its your motorcycle you can thank them with a little  "V-TWIN CANNON ACTION"  I got a record of five mice at 10 feet !:)
Feb 25, 2010. 1:39 PMhjartland says:
I'd suggest a flapper. 1, it looks cool. 2, it'll keep em from chewing the on insides and leaving room for rust. 3, dead mice stink.
Feb 13, 2010. 7:19 PMhjartland says:
Neat. Thanks!
Jul 1, 2008. 8:16 PMincorrigible packrat says:
Neat project. I get B&S engined lawnmowers at the dump all the time (wonder why?). Finally gave up fiddling with the silly things, broke down and bought myself a lawnmower. It's a Troy-Bilt with a Honda... Damn! That is one fine engine. Starts easily, runs quiet and clean. If I wasn't married already, I'd make it my bride...
Jul 21, 2009. 6:28 PMEsmagamus says:
My father managed to ruin a Honda. First, he thinks he's some kind of mechanic with lots of solutions lacking problems. Then, he changed the oil... and put some fresh 2-stroke oil! Now, guess what? A broken connecting rod!
Aug 13, 2009. 10:13 AMincorrigible packrat says:
That'd do it. Funnily enough, my own Honda hasn't been the same after a run-in with an exposed (tree) root. Hope I haven't bent the shaft...
Nov 15, 2009. 6:53 PMcandle360 says:
it's suprising how strong the cranks are on lawn mower engines. i don't think you bent the shaft but it sounds like you messed something up. I know if I had my engine on a lawn mower, it would die if it hit a rock. the custom forged crank wasn't made to handle rocks or tree roots. It was made to make power!!! lol
Aug 13, 2009. 11:53 AMEsmagamus says:
At least you didn't put two-stroke oil in it.
Sep 12, 2009. 7:25 PMincorrigible packrat says:
Oh the trauma of having a two stroke shaft...
Jul 26, 2009. 6:01 PMcandle360 says:
haha, nice. I used to do alot of mower modifications before I got a car, now I modify my car. I have an old lawn mower engine that I think puts like 15-20 horsepower with the things I've done to it. I want to rebuild it and make around 50 horsepower by turbocharging it. but that'll be sometime later
Nov 15, 2009. 12:22 PMm5industriesinc says:
imposiblle i fix these for a living and the fastest you can posiblie make the one above go before it blows is about 9-10 and a half  HP
Nov 15, 2009. 6:45 PMcandle360 says:
that doesn't make any sense since 5hp blocks are used in mini-dragsters for kids to make over 50 hp. Mine has a modified cam, custom piston, custom rod, custom crank, custom intake manifold, exhaust that's so little that it's not even telling the truth if I said it had exhaust, and modified intake and exhaust valve ports
Sep 2, 2008. 4:56 AMgeneral zee says:
Yes like you said dont use soldered copper, the solder is guaranteed to melt.
Jul 21, 2009. 6:22 PMEsmagamus says:
My brother tried to make a new muffler using a solder filled can. As soon as he pulled the cord, the mower started spitting molten lead! I'd pay to see his face!
Jul 24, 2009. 4:31 AMgeneral zee says:
thats pretty much what happened when i did it.
1-40 of 74next »
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
Author:millenniumtree
