Introduction: Homemade Hollow Core Door to Stand Up Desk
Not going into a lot of detail here, just showing a few steps of the project, you should get an idea of what to do from there....
Items used in this project:
Hollow core door
Balusters
1X4 lumber
liquid nails
base board molding
laminate flooring
screws
drill
saw
framing clamps
AWETHUM dog
other stuff I'm forgetting
Hollow core door
Balusters
1X4 lumber
liquid nails
base board molding
laminate flooring
screws
drill
saw
framing clamps
AWETHUM dog
Step 1: The Basic Frame
Find a hollow core door size that fits your needs. I then made a simple 1X4 frame so that 2 sides of the door would over hang 3 inches since this is going in a corner. AWETHUM dog is being AWETHUM.
Step 2: Balusters for Legs
I purchased 3 balusters to make a leg. I clamped them together as shown and then ran a total of 3 screws each though the left and right ones into the rear baluster, but not where the 1X4 would be. After I screwed the 3 balusters together, I cut the round ends off seen in the photo here so I had a flat surface.
Step 3:
The screws that keep the 3 balusters together are not seen from the outside when viewing the desk as shown here. I then ran screws though the 1X4 into the balusters to secure into place.
Step 4:
I had to cut the narrow ends down a little to get the correct height I wanted for my stand up desk. But just bunch them together and then shoved a rubber cap over the end.
Step 5:
Once I had the frame made and the leg screwed into place, I flipped it over and screwed it to the wall, going into studs. I then put Liquid nails on the top side of the 1X4 frame and placed the door on top with weight on it and let sit for a few hours to dry.
I had some laminate flooring left over so I put that on top of the hollow core door which I would recommend since the hollow core doors are waffer thin. I cut the laminate flooring down to size for a flush fit on the door and used a little bit of Liquid Nails to secure. I then cut some basic base board molding to size, put Liquid Nails on the edges of the door, pushed the base board molding onto it and used a braid nailer to secure. Added a bit of base board along the wall as well to finish out.
I had to go back and touch up a little bit of the paint work, no big deal.
Step 6:
The 3 balusters for a leg has been very sturdy and gave me the length I needed to make a stand up desk. Also being mounted to several wall studs helps as well.
The laminate surface his a bit of a fine texture about it, but doesn't cause me any problems when writing on a single sheet of paper directly on it. If I were to write directly on the hollow core door, it would write groves into it.
The hardest part of this whole project was figuring out how make a long leg to get the height needed for a stand up desk. I didn't want just a 2X4 or something there. Balusters was a good fit for my needs.
