Homemade Mini Lathe by Aluminium Alloy
Published
Introduction: Homemade Mini Lathe by Aluminium Alloy
Homemade mini Lathe by Aluminium Alloy
Parts and Tools:
1 pcs Aluminium Alloy Profile 650 mm x 80 mm x 40 mm.
4 pcs Aluminium Alloy 6061 120 mm x 80 mm x 12 mm
2 pcs Aluminium Alloy 6061 150 mm x 80 mm x 12 mm
Mini Lathe Chuck, Head Drll, Motor Sew Machine, and few time holiday
    • Water Contest
      Water Contest
    • Oil Contest
      Oil Contest
    • Creative Misuse Contest
    3 Discussions
    What type of bearings are you using?
    A cutting head should have a thrust bearing fitted.
    Could you please take the head stock and tail stock apart and show a measuring tape where the parts fit together? That would help a lot in showing where the different parts go. You also don't mention your angle braces in your parts list. Do you have a part number for them?
    This is a neat little idea and it appears to be an easy way to introduce yourself to working on a lathe, at least in small scales. Thanks for sharing!
    very vague instructions
