3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Homemade nearly-free Soldering Iron Stand
Step 3Remaining Assembly Steps
- bend the wire into two legs (a u-shaped arrangement, look at the pic)
- drill two holes in your baseboard to accomodate the U. The first hole is more oval-shaped, to accomodate the two diameters of wire that have to fit in there.
- nail or staple the plastic soap dish tray
- cut the sponge to nicely fit into the soap dish
note: the Coil can conveniently be removed from the holes in the base, for compact storage. Or, if collapsibility is not important, mount the wire to the board using screws, using a drilled-through hole, or any number of methods of your own invention.
FYI, when soldering, a key trick is to keep the tip nice and clean ("silvered" or "tinned"). This is the purpose of the sponge. Make sure it is wet when you're using it.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
Author:jaime9999
