Step 7: Bake it
2. For peel and stone, pick it up and shake it a few times to try to loosen up the pie. If you were very liberal with the cornmeal, it should start moving around very easily. Put the end of the peel near the back end of the stone, tilted slightly downward. Very gently shake the pie off of the peel, moving the peel back as the pie slides off. If it comes off in a total mess, have pizza delivered and try a pan the next time.
3. Check it after 6 minutes, but it can take 8-10 minutes for it to get nicely browned. You may want to rotate the pan halfway through.
4. If using a peel, slide it under the pie and transfer to a cutting surface. If using a pan, take it out and use a spatula or something to slide the pie out of the pan onto the cutting surface. If it's stuck (to the pan or to the stone), work around the stuck area gently and get it loose. It may tear a bit, but it will still be edible.
Remove these ads by
Signing Up
Not Nice
Visit Our Store »
Go Pro Today »
