The object in this picture is a homemade submersible camera housing, made possible by the silicone O-rings. (my next instructable will be the camera housing)
Quick and dirty explanation: Inject silicone adhesive straight from the tube with a caulking gun into clear Vinyl tubing, let it cure, blow the silicone out with compressed air, cut the silicone to length, re-glue it to form rings. If you want tubing, blow out the silicone before it cures...
This instructable will not only show how to make the O-rings and tubing, but go into detail about the way silicone adhesive behaves so you can exploit it, and make even more things!
Remove these ads by
Signing UpStep 1Materials
1. THERE IS A DIFFERENCE AMONG SILICONE TYPES. DO NOT USE "Silicone II", it is not pure Silicone, and will not behave as predictably as "Silicone I" , (or 100% silicone). The black Silicone is from ACE and is my favorite. Clear GE Silicone 1 is great too.
2. Clear Vinyl tubing. This is what you will be pumping the silicone into, it's the mold for the O-ring and tubing. The "I.D." or inside diameter of the tubing will be the "O.D." of the Silicone O-ring you are making.
3. Masking tape, compressed air, sharp knife, high quality caulking gun, about a week of cure time.
Crystal clear silicone and teflon tape on the outside should work ..
Also, roaches like to eat silicone cured with corn starch!
I was thinking of using standard Buna-N -326 O-rings, but places like McMaster-Carr sell them in packs of 50. Granted, the cost is only $6, but it seems like a waste to use 2 out 50. Your method would allow me to make only what I need. Plus, if I needed different sizes, I wouldn't have to buy another 50.
Maybe make some piston rings out of pvc, like an automotive piston, and bed them in the grooves with silicone?
Let me know how it turns out!!
The project has been in the planning phase for a long time. I also get as much joy from the design and build process as I do from using the results. I keep picking up ideas that will make the project more affordable and easier to make, ideas like making my own O-rings. When it gets built, there will be an Instructable to document it.
I had been contemplating to do a circular groove in a piece of soap and fill it with silicone, but this method seems much more practical. Except the fact that we have to wait that long. Do not you can make a small paper tube to dry faster? For unmolding, wet the paper and wait a few minutes to soften ...
I thought about making grooves in MDF with a router to make a channel for the silicone, and using a straight edge to level off the silicone, and the MDF will breathe enough to let the silicone dry quickly. The orings wouldnt have a round profile though. Paper is great too, in fact i cover large square floor tiles with craft paper, and squeeze silicone between them to make sheets of silicone to build stuff out of.
Woo-hoo!
ps (i think it is spelled vinyl?)
