Step 4Drilling the holes
As you can see in the picture you have to measure out how deep you have to drill the hole for the tobacco. Be careful the walls of the tobacco chamber are not to thinly constructed. If they are, the heat is going to destroy your chamber.
The walls of this pipe are 8 mm thick. The tobacco chamber has a diameter of 18 mm. and is 3 cm deep.
In the end all measurements depend on the design which you have chosen for your pipe.
Next you are going to make the hole for the mouth piece which will connect the mouth piece to the tobacco chamber. Carefully drill first the hole for the mouth piece. I used a 7 mm drill. Then change the drill to a smaller one, I used a 3 mm. Now make test fit the connection of the mouthpiece to the chamber.
comment
Add Comment
Add Comment
