3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Homemade water sprinkler
Wondering what to do with your leftover marshmallow shooters? Turn them into a water sprinkler for the kids.
Step 1Get your parts
Get your parts
You will be needing some PVC pipes, connectors and elbows, PVC cement and a connector to the garden hose. Your tools you will need is a drill with a small bit (1/8 to 1/16 inch), and pliers.
16 comments
Jun 21, 2011. 9:32 AMProjectStart says:
Cool idea! I'm wondering how well it would work at my house though, we have low water pressure at times.
Mar 12, 2011. 8:32 AMglyncastle says:
Im looking for instructions on how to build an above ground sprinkler. I dont want to dig trenches! Just need something that will water a large area at a time.
Jun 10, 2007. 4:06 PMKiteman says:
To make this Instructable complete and eco-friendly, you need to include a device that syphons used bathwater to run the sprinkler ;-)
Sep 4, 2010. 11:35 AMryandean98 says:
You Wouldn't Want to Play In That!
Jul 4, 2008. 6:38 PMBartboy says:
smart
Jul 25, 2010. 2:21 PMjustbennett says:
I built one for a party before I saw your instructable. I didn't bother gluing at all. I dry fit the pipes with a little pressure and a slight twist. If I decide to take it apart for the winter for storage, I'll be good to go. I have my hose on a splitter with a valve on it. This way I could sit by the spigot and adjust the fountain height. I would dare kids to stand inside the square and entice them with a measly little trickle. Then when they were inside the square I'd give it to them full blast. They loved it. Another benefit to not gluing: you can adjust the in/out angles of each pipe. I built mine for about $3.50 in parts.
May 30, 2010. 9:19 AMahmad2117 says:
i think its better to have smaller holes than bigger holes
Jul 9, 2009. 9:11 AMTofu says:
After my store bought sprinklers kept getting destroyed over the winter (the plastic they use doesn't like our -20F temps in my garage) I decided to create my own sprinkler from the PVC sections I have stowed away. Thought I'd check to see if someone else had done it to see what I need to connect my hose to PVC and found this. My problem with your Instructable is that you don't describe any of the parts. You don't list where you got the parts, what size pipe you used, what the hose connector's size (and approximate expense) is, etc.. I'm making mine and I'll hopefully post what I made.
Aug 9, 2007. 7:48 PMdrake says:
Very cool!
Jun 11, 2007. 8:54 AMfeign says:
I made one of those this weekend for my kids. I made mine approx. 6.5 feet high and 4.5 feet wide and it sprays(rains) the water down so the kids used it to make a water slide and a car/ bike wash. I love PVC.
Jul 21, 2007. 10:40 PMseabeethom says:
how do you make that sprinkler? i need to make something like that.
Jun 12, 2007. 4:09 PMthreebean says:
Instead of cementing the pieces together, could you use silicone sealant. That way you could pull the parts back off and change your setup when you wanted to?
Jun 12, 2007. 2:18 PMsawdust13 says:
It looks like it will water a cross area not a square or circle. If the holes are drilled at angles can you get closer to a round or square area.? I think I have enough parts to make one.
Jun 10, 2007. 11:08 AMBurningApple says:
I like the idea.
Now to get a lawn. :)
Jun 10, 2007. 6:25 AMlemonie says:
While it's fairly obvious how to do this, your Instructable doesn't explain how to do this. L
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
Author:sjogan
Mad Scientist.
