3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Homemade wax seals part 1
How to make wax seals for invitations, gifts, or other stuff. Everything besides the seal wax is homemade from super easy to find stuff.
what you need:
A grinding wheel for use with a drill press (True Value, $3.50)
Limestone rock
Dremel
"Odd broken drill bit looking thing" dremel bit ---Update! its called an "End-mill"
Drill press
Sand paper
Pencil
Soft clay
At least 3 fingers
Step 1Find a limestone rock
Find a cool rock that kinda looks like this. I don't know if you can see this but it's
*kind of* shaped like a 3 faced pyramid with a *kind of* flat base. I'm holding the rock with the base facing up.
32 comments
Nov 18, 2007. 12:25 AMthewoodcarver says:
Good job , Maybe Soapstone since it carves easy you can use a butter knife and sandpaper on it
Jul 21, 2011. 9:06 AMScurvymcdiggle says:
soapstone would be perfect for this. you can get harder grades of soapstone as well that need a little more effort to work. and it wouldnt degrade. it would however be sensitve to scatching and and dropping. i love soapstone. awesome stuff.
Feb 9, 2009. 3:36 PMthepelton says:
Soapstone is available through woodcraft.com
Nov 29, 2007. 7:29 PMthewoodcarver says:
They use to make sinks out of soapstone ,I remember one on our back porch back in the mid 60's the house was built in 1920 or so and I seem to remember seeing it used as a fireplace or woodstove
I have a soapstone ashtray that is missing I am told a carved matchbox but i did buy it to used as a base for something else I was carving (got to finish that someday)after I finish my x mas gifts I will find the chunk of soapstone I have and try one of these
Feb 14, 2009. 5:58 PMMetalcaster14 says:
be nice
Nov 17, 2007. 7:48 AMCryptonat says:
Does it have to be stone? Could you use wood, or are we trying to avoid porous materials?
Feb 9, 2009. 3:41 PMthepelton says:
I have made seals out of wood, but I use hardwoods that are varnished, waxed and buffed before I use them. Preferably a wood that is far less porous than red oak, and harder than cherry. I have had success with hard maple and walnut, and was planning to use some foreign woods like yellowheart and purpleheart.
Nov 18, 2007. 9:00 PMAusmaus says:
you could always go really old fashioned and make a signet ring.
Nov 17, 2007. 9:44 AMdarkmuskrat says:
I think would be fine as long as its been laquered dude. I just think the stone is for looks.
Nov 17, 2007. 7:57 PMjtobako says:
I think the thermal mass (ie the stone stays cold) is important so that the wax 'freezes' before it can stick. A wood seal may have to be dipped in water rather than lacquered.
Jan 9, 2009. 7:47 PMdwhp says:
duh
Jan 4, 2009. 12:20 PM=SMART= says:
Awesome !
Oct 11, 2008. 2:21 PMmaking_hands says:
thanks for the help but I prefer you make the seal with metal or copper stuff like that. I was hopping you would show me how to make the wax seal, I am so tired of having to make my own :(
Feb 22, 2008. 12:45 PMPyroMaster007 says:
Cool.
Nov 17, 2007. 7:39 AMgotclawz1 says:
do i have to use limestone or can i just use a rock or maybe some leftover marble i have lying around
Nov 17, 2007. 4:29 PMmaninamousesuit says:
i had sealing wax for my wedding invites but i ran out so i used a red crayon and it worked perfectly
Nov 18, 2007. 12:01 PMgamer says:
If you want to make an "A" mark it as an "A", thats funny. very nice idea. -gamer
Nov 17, 2007. 7:37 PMegreen767 says:
i've always wanted to do this sweet instructable!
Nov 17, 2007. 10:51 AMsnoyes says:
For the wax seals on our wedding invitation, I just used a $3 rubber stamp that had my initial in relief, and a box of ordinary red candles from the dollar store.
Nov 16, 2007. 2:34 PMstranoster says:
Looks Great! I was going to buy a seal about 3 weeks ago but then I'd have been set back about $100. Wasn't going to happen. Good instructions with clear pictures. Nice to see macro mode still gets used occasionally. :)
Nov 17, 2007. 1:54 AMstranoster says:
Maybe a gelatin and candle wax mix? I'm not sure if it'd combine but it would make it less brittle. The easiest solution is to buy a coloured candle and just burn it I suppose. Again this is a great instructable
Nov 16, 2007. 2:33 PMPocketSized says:
Thanks for the Instructable. I really like it. I'm going to have it give it a try.
Nov 16, 2007. 2:32 PMjoejoerowley says:
Very Cool! Well done!
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
316
Author:nepheron(MakerWeekend)
I have an awesome blog @ www.makerweekend.com Im Calvin Drews, and I love to learn, experiment, invent, create, repair, and generally just do things myself. A sort of modern jack of all trades, mast...
more »
