This Instructable is splitted in two parts: theory and practice. If you are not interested in all the math and physics behind the project, you can jump directly to the practice section. If you want to know how to retrive all measurement, or even to customize your pipes, then proceed with next step.
Remove these ads by
Signing UpStep 1Theory
As I've aforementioned, you can skip this passage if you don't want (or need) to understand the physics beyond a pan flute.
OK, if you're reading those words you want to know more. I'm here for this!
A pan flute is a mere group of tubes with a closed end (called closed cylinder, even if one end is open). Each tube have a different length but, usually, the same diameter of all other tubes.
The length of the tube influence the pitch: longer tubes produce lower notes, shorter tubes produce higher notes.
The inner diameter of the tube influence the speed of blow needed to make the sound audible: smaller diameter means less blow, greater diameter means more blow.
Pretty simple, uh? No math, no strange formulas...
Now we need to find a precise relation between tube length and note pitch. Luckily, some physician (well, actually a lot of physician) already studied this matter creating and developing a branch of physics called acoustic. So we can "stole" their results to serve our scopes.
The formula we need is the one in the first pic. Here is the meaning of various symbols:
- L is the length of the tube
- v is the speed of sound
- f is the frequency
Fine. Now we need to determine which notes we want to produce, and their frequencies. I'm going to make a full octave pan flute, so I need 13 tubes: C, C#/Db, D, D#/Eb, E, F, F#/Gb, G, G#/Ab, A, A#/Bb, B and C again. Each tube will produce a note a semitone higher than the previous one and a semitone lower than the next one.
Since it's is too generic saying "I want to play an E", we must specify also the octave. In my case the first C is a C4 and the last C is a C5. This make the A an A4, with a frequency defined to be 440 Hz (modern concert pitch). From this we can determine all other frequencies using the second formula (second pic, obviously). The n is the number of semitones between the note we want and the A4. If the note is lower than n will be negative, if the note is higher it will be positive.
One advise: Maybe it would be "safer" to cut the tubes a little bit longer (a few mm). Then, using the needle file and a good tuner you can tune each tube at the exact pitch. ;-)
also, you could use epoxy to bind the tubes together
Our first attempt just used insulating tape to close one end of the tubes - this didn't work at all. We then tried stiff cardboard held in place with insulating tape which worked perfectly.
I only found out recently that the way they're played in the Andes is for two players to blow alternate notes on the pipes, so each player is only playing half the tune with the notes bouncing back and forth between them.
After all, Stradivari was an excellent violin maker, but a poor violin player.
The way Andes performers play their instrument is very interesting, I'd like to see them in action.
I can't find a video of the alternate blowing either. We get a few Andean bands busking in the High Street during the year and one of them explained and demonstrated the technique once. Since then I've seen others do it.
My stepmom played the fiddle and a mouth harp.
My dad played the Tabor Drum, the fife, the flute, and a dozen other random instruments.
I also played the flute. (I liked juggling better than musical instruments)
We performed with an Irish Stepdancing group. It was quite fun!
This would be great for those who can't find a pan flute. (I'm also excited for your tin whistle!)
Very nice job!
Sadly, I've seen only one... and desolate...
However, I hope I will not make you wait too long for the tin whistle. Stay tuned!
