Homemade Wood Mini Lathe With Hand Drill
Published
Introduction: Homemade Wood Mini Lathe With Hand Drill
Homemade wood mini lathe by hand Drill very easy and cheap with old hand drill,
Aluminium Alloy Profile 600 mm x 80 mm x 40 mm
2 pcs Aluminium Alloy 6061 160 mm x 600 mm x 12 mm
1 pcs Aluminium Alloy 6061 80 mm x 80 mm x 12 mm
1 pcs Aluminium Alloy 6061 160 mm x 80 mm x 12 mm
1 old drill broken and 1 1 old drill nice work
    • Woodworking Contest
      Woodworking Contest
    • Oil Contest
      Oil Contest
    • Make it Move Contest
    2 Comments
    Very neat! No soldering... Ideal for ocassional work!
    Is there a way to buy these pieces already made, like a kit?
    This is very neatly made. In my experience, an electric drill does not produce enough speed to make smooth cuts on a lathe, or to finish and polish a wood turning. Perhaps you intend to use smaller metal rod for your turnings and a file for a cutting tool. If you do turn wooden items, a Dremel tool with a burr tool or a grinding wheel, or even a sanding drum might help a lot.
