Picture of Homemake Wooden GoKart 2.0
Well, after my first and mostly successful wooden gokart, I decided to build a sturdier and better one. I used the same wheels, engine, axles, and seat from the first one. For specific details on mounting the engine, sprocket, and wheels, visit my first gokart.  This is definitely an improvement from the first. For your convenience, I made a 3D Sketchup model. Download it here. The following steps contain pictures from Sketchup. I recommend you use Sketchup to find the exact dimensions.
Step 1: Step one
Picture of Step one
Put two 3 1/2" x 1 1/2" x 75" beams 3 1/2" apart.
Step 3: Step Three
Attach two 15" long beams
Step 4: Step Four
Picture of Step Four
Attach a 10 1/2" long beam to tilt the seat bottom. Install the seat bottom.
Step 5: Step Five
Picture of Step Five
Attach the seat back and install a brace. Place the engine on the mount.
Step 6: Step Six
Attach a beam underneath the engine, and install blocks underneath that on either side. Drill holes through either side for the axle. Insert axle and and attach sprocket to axle or wheel then install wheels.
Step 7: Step Seven
Picture of Step Seven
Do the same for the front. Add blocks, axle, and wheels.
Step 9: Finished
Hopefully, I have given you a complete tutorial on how to build your own gokart. Some things on the Sketchup version may be slightly different from the real gokart, but the dimensions are accurate.
1-40 of 156Next »
Ethan_Lundy2 months ago
I got the list how much would the whole thing cost?
Is there a list of the materials?
jpatel3642 years ago
where is the brake
hunter13 (author)  jpatel3642 years ago
Nowhere, thats what makes it so fun ;)
i put a metal piece by my foot that i can kick so it slows the tires down fast :)
Is it possible to make from metal?
of course but the steering may be a little harsh but would be better be cause less chance of throttle snapping or any piece of the kart
_mamanssi4 months ago
Hi... may I know what type of wood did you used? and are there any other suitable type of woods other than the one that you used?
ProFsxVideos6 months ago
Hey. Where did you get the axle, bearings and wheels. This is a WIP right now for me!!
tseselskyd6 months ago
This thing is awesome!
I would like to make something like this for my son but pedal powered.
Any thoughts? Ideas? He's 6.
Thanks.
james_rea0011 months ago
would threaded rod be ok to use for axles?
What type of engine did you use?
hunter13 (author)  Adamthegenius121 year ago
5hp briggs and stratton flathead
engineer31 year ago
what type of engine is it? i go to the briggs and stratton website and under engines they have sub menues: push mower, riding mower, snow blower, commercial, racing, and other. do you know what type the engine is from those categories?
How would you mount the motor? Just with standard bolts that would fit with the engine?
hunter13 (author)  aguiarnumber41 year ago
Yes, just with bolts running through the engine block then down through the wood.
neonkid1 year ago
brakes?
jhansher1 year ago
What size tires did you use?
hunter13 (author)  jhansher1 year ago
10" or so. Basically wagon wheels.
where did u get the tires
willisdaye1 year ago
I just finished mine. IT. ROCKS. got the Honda clone from harbor freight, and i installed brakes, too. i hooked up a real throttle cable, so there is a gas pedal, and there are two levers for steering, not just one. I used a chopped up pool noodle for seat padding.
Thanks for the instructable, man.
slange41 year ago
You should try to make a bigger gear off the engine and a smaller connected to rear axle
How are you attaching the wheels to the axle? Also, how did you attach the sprocket to the wheel?
s252161 year ago
one more question- where did you get the sprocket? they seem to fit perfectly to the wheel.
I made this exact go cart to the exact dimensions a while ago. I used a 5 hp tiller engine same as you. When i tilted the steering just a little bit a 2o kmph the cart flip and i broke 8 bones and had 7 bone contusions. and the exaust burned me when the engine landed on me. bed ridden for 4 years. Just consider danger before you make this.
seems legit -.-
hunter13 (author)  mechanic19581 year ago
My, that's bad. Sorry to here that. Yes, use all caution.
is a clutch needed or is it optional
needed definitely not optional
mstandring2 years ago
http://www.youtube.com/watch?v=bF5yROdMuv4
wildafrican2 years ago
are there BRAKES.
s252162 years ago
Where did you get your bearings for the back and front wheels?
hunter13 (author)  s252162 years ago
The front wheels came with bearings and are free spinning on the axle. the rear wheels also came with bearings, but I bolted the wheels to the axle to connect it to the engine.
how fast does that go approximately in MPH??? Plz reply
21.4 mph
could u please list all the materials u used
Wood, 4 bearings, 2 steel dowels, 4 wheels, 1 engine, misc bolts and nuts, screws, sprocket, clutch, chain. This was intended to be a body update for my first gokart.
im planning on making that but id like to add some body mods to make it look cooler got any ideas
1-40 of 156Next »
