Remove these ads by
Signing UpStep 1Cut Out The Wood
For the piece that will be the top, cut out the neck pocket and pickup cavity. The extra hole below the pickup cavity is for the on/off switch. I used an on/off switch instead of a potentiometer for two reasons: 1. Normally I only use the volume knob on a guitar for turning it all the way down and 2. I was using a Strat tremolo bridge and the on/off switch fit nicely in the tremolo arm hole.
For the piece that will be the bottom, I routed where the wires will go. Notice that when the top piece is on the bottom piece the routed wire tunnel will intersect both the pickup cavity and the switch cavity. That wire tunnel also goes to where the jack will be.
That would work for Stewie Griffen but not Homer. Plus, I hang this beast on the wall and Homer needs to be upright in that orientation!
As for the neck, I just cut the neck pocket out of the top piece of wood then just bolted the neck to the bottom piece of wood. No funky angles or anything.
It was really good up to the sudden jump from 1/3 done to complete.
