Step 20Insert lolly stick or coffee stirrer
You could just glue gun glue the doughnut straight to the top of the base. In which case your job is done. OR
Use either a lolly stick or a disposable wooden coffee stirrer. Poke the stick through the top hole that you have cut and making sure it is at a slight angle facing back, push it into the bottom cardboard. The cardboard will dent in slightly and a mark will appear on the bottom surface. temporarily remove the stick and make a small cut in the bottom of the base so that the stick can poke through. Put a blob of glue gun glue in the hole and push the stick through again so that it is coated in the glue gun glue and then push it back so that doesn't actually poke out of the bottom of the base stand.
Add Comment
