Homopolar Motor With Five Speed Manual Stick-Shift
video Homopolar Motor With Five Speed Manual Stick-Shift
This video show how to build a homopolar motor that's really different...it's got a five-speed shifter!
The homopolar motor is the simplest design electrical motor in the world. It uses a battery, a neodymium magnet and a wire. Usually, either the copper wire or the magnet rotates. In this case the battery rotates.
Here, I've used a battery, a neo magnet, and a copper wire wrapped around a coat-hanger. The coat-hanger acts as both electrical connection and support for the hanging battery. Coins are used to change speeds of the rotating "battery-plus-change" motor.
I've been recently told that US coins, being non-magnetic, won't work for this Instructable. (Sorry about that!) Perhaps the US coins could be glued together to make it work. Furthermore, some Canadian pennies are magnetic and some are not.
You can order the BEST neodymium super-magnets from K&J Magnetics here.
See more of my homopolar motor videos at :
http://ca.youtube.com/MrfixitRick
81 comments
1-40 of 81next »
Aug 18, 2011. 7:17 AMvruiz3 says:
unexplained things #2 homopolar motor with 5 speed shft. :P
Jul 17, 2011. 10:40 AMtechnician ace says:
your idea is a wonderful and revolutionary idea ,sir
Mar 4, 2011. 5:01 PMSky_line91 says:
do you happen to know if this is possible with wires coming from a power source instead of a battery?
Mar 9, 2011. 5:43 AMSky_line91 says:
awesome, thanks
Dec 29, 2009. 10:21 PMdivyanshu007 says:
 how does the movemement of the shifter result in the variation in the speed
Feb 8, 2011. 10:51 AMRottom says:
would it be possible to just stack different thickness and diameters of the neo mags and apply the gear theory to thus?
Mar 25, 2010. 9:49 AMShingoshi says:
I'm guessing that using any circular magnetic surface like one having a conical cross-section would actually give you a variable rate transmission. No more fixed speed shifts. Simply sliding the shifter from one radius to another would immediately change the speed of the device without ever having a discontinuation in rotation.
Xavian-Anderson Macpherson
ShingoshiDao
Mar 25, 2010. 9:58 AMShingoshi says:
Come to think of it. A sewing thimble would work perfectly for testing the idea. Because the less variation in mass, the more accurately one can view the effect of changing the radius alone has. I would flip the cone of the thimble to cover the end of the magnet and extend over the battery. The result will be more stability avoiding the necessity to align coins for proper rotation.
ShingoshiDao
Mar 25, 2010. 1:37 PMShingoshi says:
I just need to find myself some small NbFeB magnets. I'm thinking of a few devices around my house that I could strip apart to acquire the magnets from. So if I do get to do it, I'll definitely post my results here and elsewhere (ie. You Tube).
ShingoshiDao
Jan 3, 2011. 8:41 AMJ_gilbert6911 says:
I am doing this for a science project... somewhat. I am having trouble getting it to work. The thing i dont understand is the coin part. Do you need coins or magnets or both?
Jan 4, 2011. 8:08 AMJ_gilbert6911 says:
Would this type work? 13/16" dia. x 1/16" thick Grade N42 - Nickel Plated
Jan 6, 2011. 8:24 AMJ_gilbert6911 says:
I bought a pack of 10 from K&J Magnetics. Would using several work?
Jan 7, 2011. 8:35 AMJ_gilbert6911 says:
I went to the local home-depot and just gor regular copper-wire. Bought a few D batteries. Then from my science teacher i got a 2", believe its a black hole magnet (like refrigerator magnets but bigger and with a hole in the middle) I wrapped the magnet in tin foil and shaped the wire to fit around it. IT WORKS!!! IT WORKS!!! lol :) So far i have made the heart shape and somewhat of a spiral. Anyone with any ideas for other cool shapes??
Jan 26, 2010. 7:49 PMcamaroboy says:
how much torque does 1st gear have?
Feb 2, 2010. 8:25 PMcamaroboy says:
why does the battery spin faster when the wire touches the coin closest to the magnet/battery?
Feb 2, 2010. 8:18 PMcamaroboy says:
how come mine doesnt work properly? it only works when touching the magnet. seriously, whats wrong with mine?????????
Jan 26, 2010. 10:03 AMcamaroboy says:
how many rpm can the 5 th speed do?
Jan 26, 2010. 8:09 PMcamaroboy says:
omg this things awesome. im doing it for my science project, and im gonna burn it to the ground. lol just kidding. again great project and keep up the good work.
Nov 30, 2009. 4:58 PMToastaG says:
The shifter reminds me of a record player.
Jan 27, 2008. 11:05 AMfinlandrocks says:
ok no-one has asked a question about the use of the battery, does the batteries contents act as a magnet or fly-weight or both? would using a larger battery produce a faster motor or more torque etc? im really interested in this odd motor. thanks,simon.
Jan 27, 2008. 11:05 PMfinlandrocks says:
hey thanks mrfixits for your reply, so im guessing that the batteries charge disspates with the use of the homopolar motor, you should try the experiment using D cell ansmann 8000mah batteries! :) cheers''
Oct 22, 2009. 1:20 AMDr. dB says:
Cripes! ...don't forget your Kevlar undies, too!
Oct 12, 2009. 4:23 PMarea36 says:
Mumble mumble mumble
Sep 27, 2009. 4:46 PMGianniMora says:
boring...
Sep 19, 2009. 8:33 PMNatureBoom21 says:
Yay! During a trip to canada I had the brain to get a few coins
1-40 of 81next »
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
229
Author:mrfixitrick(Mrfixitricks Youtube Channel)
I am re-inventing myself as an inventor, after too many years as a mechanic! I enjoy learning from Tesla disc Turbines, magnetic motors, and Crystal Quantum Radios. "All children are artists. The ...
more »
