This video show how to build a homopolar motor that's really different...it's got a five-speed shifter!
The homopolar motor is the simplest design electrical motor in the world. It uses a battery, a neodymium magnet and a wire. Usually, either the copper wire or the magnet rotates. In this case the battery rotates.
Here, I've used a battery, a neo magnet, and a copper wire wrapped around a coat-hanger. The coat-hanger acts as both electrical connection and support for the hanging battery. Coins are used to change speeds of the rotating "battery-plus-change" motor.
I've been recently told that US coins, being non-magnetic, won't work for this Instructable. (Sorry about that!) Perhaps the US coins could be glued together to make it work. Furthermore, some Canadian pennies are magnetic and some are not.
You can order the BEST neodymium super-magnets from K&J Magnetics here.
See more of my homopolar motor videos at :
http://ca.youtube.com/MrfixitRick
Generally, the larger radius coins will spin slower but with more torque. This torque and speed could be calculated using the Lorentz force principles.
Xavian-Anderson Macpherson
ShingoshiDao
ShingoshiDao
ShingoshiDao
The magnet is necessary, and must be a powerful neodymium type magnet, found at a place like K& J Magnetics.
I just tried a 3/4" x 1/16" and it would not hold. 3 or 4 of them stacked will likely work.
A 1/2" x 1/4" N52 magnet will work. I prefer a stronger N52 magnet, and definitely thicker than 1/16", at least 3/8" thickness.
You could stack magnets like coins as well. For example, use a 1", then the 13/16" x 1/16", then a 5/8", 1/2", etc. stacked.
Then remove one or two magnets for a little less weight. The coins are optional to vary the speed.
The hanger tip where the battery hangs is somewhat critical. It must be rounded and smooth, not a sharp point or edge. The magnetized battery hangs in better that way.
A thicker wire coat-hanger will work better than a thin wire one.
I didn't think that would work!
Have a look at this movie that shows wire-formed dragonflies and butterflies using the homopolar motor idea.
And the radius is smaller, making it run faster.
The coins work best if they are magnetic like Canadian coins or magnetic coins from a magic shop.
