Introduction: Honda Civic CR-V HR-V Bonnet Hood Release Latch Lever Pull Cable Handle Repair Fix Kit Replacement Install Instruction Guide
Picture of Honda Civic CR-V HR-V Bonnet Hood Release Latch Lever Pull Cable Handle Repair Fix Kit Replacement Install Instruction Guide
The Problem
The plastic bonnet release handle snaps making it difficult to open the bonnet.
The plastic handle on the bonnet release cable which you pull to release the bonnet from inside the car is made from a poor-quality plastic. This isn’t suited to the force required to release the bonnet. This inevitably snaps and breaks off making it difficult to release and lift the bonnet. This previously necessitated the complete replacement of the bonnet release cable; which can be expensive and time consuming to fit.
Symptoms of the fault
Bonnet release plastic handle snapped off. Cracked or damaged. Inability to open vehicles bonnet. Release handle broken off or missing.
Vehicles affected and compatibility
Honda Civic 1996- 2000
Honda Civic 2001-2005
Honda HR-V 1999-2006
Honda CR-V 1997-2006
Honda Element 2003-2011
Honda Ridgeline 2006-2014
This information is for guidance only as models vary by region. Please inspect your release cable to check that it is visually the same as our images.
Associated part numbers:
74130-SJC-A00ZA, 74130-S5D-A01ZA, 74130SJCA00ZA, 74130S5DA01ZA, 74130-S5A-013ZA, 74130S5A013ZA, 74130-SNA-A01ZC, 74130SNAA01ZC.
Our solution
Fit our high-quality metal handle and restore your bonnet release mechanism instantly.
Fit our replacement metal handle in situ and save the cost and time of replacing the complete cable mechanism.
Our handle fits on the end of the cable and tightly fastens restoring use of the cable. The handle can be installed in as little as 10 minutes and restores full function for the life of the vehicle.
Using our handle there is no need to replace the complete cable mechanism. This can be very expensive, time consuming and would only fail again.
Our handle is CNC machined from billet aluminium, polished, black anodised then laser engraved with the car icon (not a sticker!) to match the look of the OEM handle but with the strength of a metal part.
Our part locks securely using two discreet set screws ensuring the tightest fit to the cable. The best solution to this very common fault.
You will receive
1x Billet aluminium black anodised and laser etched handle.
2x Fastening grub screws.
1x Allen key tool.
Step 1: Remove Old Handle Plastic
Picture of Remove Old Handle Plastic
This repair can normally be carried out in situ on the vehicle, we carried out the repair here on the bench for clarity.
Measure and mark 24mm from the metal end of handle rod.
Using a Dremmel or suitable cutting tool cut away the plastic up to this point to expose the metal core. Cut away the plastic slowly and in increments so as not to damage the metal core.
Step 2: Fit Our New Handle
Picture of Fit Our New Handle
Slide our handle over the metal core of the rod and fasten the two set screws using the allen key to secure the handle tightly to the rod core.
This will restore function, test the operation and further tighten the set screws if required.
This completes the repair. If you need any further guidance on this install or would like to purchase the parts shown please call us on +44 01843 446643 or email us at sales@x8r.co.uk.
Please also check out our instruction guide on YouTube.
www.x8r.co.uk Installation is carried out at installers risk, if unsure please contact us or a professional, X8R Ltd cannot be held responsible for any adverse result of installing this product or any injuries caused by install, if in doubt ask a professional. All images and texts are copyright X8R Ltd 2017.
About This Instructable
67views
0favorites
More by x8rltd:Audi VW 2.0 TFSI T FSI Inlet Intake Manifold Swirl Flap Runner Delete Repair Kit Plate Blanks Install Instruction GuideAudi SEAT Skoda VW VAG 2.0 TDI Intake Inlet Manifold Flap Actuator Motor Repair Bracket P2015 Error Fix Kit Install Instruction GuideNew VW Beetle Interior Door Grab Pull Metal Handles Replacement Repair Fix Kit Install Instructions Guide
Add instructable to:
