Honda Civic Speedometer Light Upgrade
1,515
21
Published
Introduction: Honda Civic Speedometer Light Upgrade
About: tinkerer
1 m RGB LED strip non waterprooph its easier to bend
LED strip remote control (optional)
Nail polish remover
30/40 pcs Qtips
Screw driver
Step 1: Disassembly
To remove the cover there are to screws on the top after that 4 that hold the speedometer 2 top 2 bottom
Step 2: Its All Clips
After you get the clear plastic and the bezel you can unscrew from the back the gauges
Step 3: Nail Clean
It looks like this
Should look like this
Step 4: Dont Miss It
You dont have to be very precise just make sure you didn't forget any line or number by holding it against the light
The numbers and lines should let the light thru without changing the color
Step 5: LED
Trial and error
Arrange the LED strip as u wish just make sure its gona light all the number properly
If you choose RGB it might glow some numbers more or less or even show one color more than the other.
v2.0 addreseble LED strip :)
    • Casting Contest
      Casting Contest
    • Woodworking Contest
      Woodworking Contest
    • Make it Move Contest
    2 Comments
    +1 on your ible.
    Very well done no lady I know would dig into a car for art improvement Kudos !
    Just got an idea but i aint that smart and dont have the time to do it.
    Using addresable LED strip and an arduino to program several color choices and choose between them by a single button or even better tap in the ECU read the data and use those to change the color instead of moving the needles in the speedometer gauge.
    Ex: all white numbers just the 0km/h green and 1000rpm green as you step on the gas the green color goes up and somewhere changes to blue to indicate city limit speed and after that red.
    Needles are so last century.
    It would be awesome for something like that.
