3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Honey Harvest and Extraction
This instructable features honey harvest and extraction. While it is less likely that anyone would do this on their own if they are not a beekeeper, this might be useful for those who aspire to become one.
Bees are really great and easy to keep, even in the urban environment! As Novella Carpenter calls them, bees are "gateway animal for urban farmers". All you need is some space in the backyard/deck.
The process of honey harvesting and extraction most likely happens on a separate days. These are the tools required:
Honey Harvest
1) beekeepers suite - mesh helmet and folding veil would do it, with some layers of clothes
2) smoker with fuel (dry branches, leaves, etc.) and a lighter
3) frame super - where frames with honey combs will be put for transportation
4) sting resistant gloves
5) hive tool - to move the frames, scrape wax, etc.
Honey Extraction
1) heated knife - to unseal honey cells
2) uncapping fork - to unseal honey cells missed by the heated knife
3) tub for wax/honey
4) extractor! - fancy cylindrical piece of equipment, used to extract honey
5) food-grade bucket - to catch honey out of the extractor
6) double sieve - catches wax and impurities as honey is poured from extractor
7) containers - final destination of honey before consumption
Step 1Introductions
Introductions
Before we begin, let me first introduce Her Majesty: Apis mellifica (honey bee in Latin)! Also, here are some hard working worker bees, bees with pollen on their legs and one cutie stuck in the nectar with pollen! They collectively make a honey harvest possible!
42 comments
1-40 of 42next »
Feb 11, 2012. 5:38 PMbluescrubby says:
Excellent instructable, great pictures! I would love to take up beekeeping someday.
I have a question about what's produced during extraction. Our friend gave us some beeswax that her relative made, and also passed along a small jar of brown-colored liquid that has little bits of wax and some other solids in it. It smells like honey. It's also fermenting like heck--I have to let the pressure out of the jar a few times a day. Any idea what this is, and what it can be used for? Thanks!
Dec 9, 2009. 9:58 AMyouevolve says:
Heated knives are expensive. Since I only have 2 hives, I use a thrift store bread knife to decap. If the frames are right out of the hive and still warm it cuts perfectly. If I need to store the frames for a bit I use a container of hot water to store the knife between cuts. The warmed blade makes short work.
Also, as the author says, only extract capped cells. Uncapped cells have too much water content and will ferment - and not in a good way. Voice of experience talking....
Great ible!
Jan 2, 2012. 10:44 PMBushie says:
Not so expensive once your hive numbers have grown to dozens...
My own small honey extracting plant (set up..) here could handle between 120 and 200+ hives, depending on the annual production levels (which can vary widely, from one region to another, and from year-to-year - from less than 50lbs to over 400lbs per hive, over twelve months..).
AND this is only a part-time/sideline operation ~ keep in mind that full-time commercial apiarists are operating from a few hundred to several thousand hives ~ and use extractors that hold anywhere between (maybe) 36 frames up to 196 frames !!!
Dec 10, 2009. 7:52 AMVery Interesting says:
What is your take on the disappearing bee colonies? ( I went to bee keeping school years ago, and love this ible!)
Apr 3, 2010. 5:07 PMMadMan.inc says:
 A pesticide made from from nicotine called niconoids  these were olny used by tobacco farmers until the anti smoking legislation made the demand for there product to go down that made the niconoid pesticide cheaper then other pesticides.
   These pesticides kill bug by reducing there immune system.  Causing some bees to fall victim to there natural killers wax moths and mites.
   I
Jan 2, 2012. 10:24 PMBushie says:
There are also other forms of "micro-encapsulated" pesticides, all of which can find their way into the hives pollen (protein) supplies = "death from a thousand cuts", as they are gradually poisoned out.
Pesticide sprays are especially a bad and exacerbated problem when time and/or cash-strapped farmers ignore the laws (where they're not supposed to spray flowering plants; nor in windy conditions..)) and spray at the wrong times..
Besides pesticides, also consider the extra stresses placed on the hives from land clearing, other pollutants, climate change ~ even if the pesticides don't finish them, then their stressed and weakened condition then increasingly "pre-disposes" them to certain diseases ~ which they may have withstood in better (read: healthier..) conditions.
You may see certain "mass media" releases trying to blame exotic diseases for this increased "die back" ~ but check the sources (back-track, and "follow the money trail"), and you will find it is the very same pesticide/pharmaceutical companies that cause the initial problems that are now producing these smoke-screens, and mislead the public. Shades of the tobacco and oil companies before them (no real surprise there, though - as those companies often share the same owners/directors/PR_people..).
Jan 2, 2012. 10:30 PMBushie says:
The new name, "CCD" is part of that media campaign I mention above ~ putting a new name on a problem makes it sound like it's a new situation ~ but the truth is that these problems have been building since the 1960s...
Until the pesticide/pollution/land-clearing problems finally went past their "critical threshold" over this past decade ~ and now everything is falling apart..
Dec 11, 2009. 3:22 PMVery Interesting says:
I also wonder if the movement of hives several times, to various fields during the growing season, is just too much for them to handle. "Dang, Buzz, Where'd the hive go now?" ..... Croak......
But true, I think the poor little guys defenses are way down.
Love the pictures - they're sweet!
Jan 2, 2012. 10:34 PMBushie says:
Don't make the mistake of "confusing cause and effects..", here ~
IF the hives are healthy and strong, with good nutritional status, they can withstand being moved up to 3, 4, even 5 times over a year..
IF already pre-stressed from other factors being mentioned in this discussion, than being moved too often will only knock them around further.
Dec 15, 2009. 8:22 PMVery Interesting says:
The poor drones get booted for the winter too! (Oops, I mean they go on vacation in Hawaii for the winter....yeah, that's the ticket! Much better pollen there huh?)
Jan 10, 2011. 11:27 AMHaldan says:
For anyone who tries to buy a 'harvesting super' it appears to be a standard 5 frame 'nucleus colony' box typically referred to as a 'nuc box'. The smaller dimensions will make it easier to carry full frames of honey and keep them safe from damage. I had never thought of using one for that purpose but at a hobbyist level of production that is a great size to safely and conviently handle the amounts of honey you are likely to collect in a day. .
Jan 2, 2012. 10:01 PMBushie says:
Build your own carry box out of 10"x1" (nominal - dressed would be just over 3/4" thick..) pine timber, with a ply', metal or masonite base (well sealed and painted.) sized to carry between 4 and 8 frames depending on your personal strength - much cheaper than buying one !
May 12, 2011. 7:59 AMburdockwing says:
I cant get ahold of an extractor thing like what you have so can you recomend an easier solution besides teaming up with an experienced bee keeper because I cant find one.
Jan 2, 2012. 9:57 PMBushie says:
You could consider using comb honey supers for honey harvesting - doesn't require an additional extracting plant.
If you only have one or two hives, you could also consider "cut comb" honey harvesting (using a knife to cut the entire comb out of the frame, and then cutting into small "sections"..), until you can source a small second-hand 2 (or 3)-frame extractor from somewhere.
Aug 29, 2010. 6:23 PMJavin007 says:
If you don't mind, how much did all of the equipment cost? Do you own your own extractor?
Aug 30, 2010. 10:28 AMJavin007 says:
I forgot to ask, about how much honey does the bee keeper let you have for hosting one hive? I could go through a LOT of honey...
Aug 30, 2010. 10:22 AMJavin007 says:
Wow, that's an excellent idea! I didn't even know people did this!
Strangely enough, this is part of why I've wanted to keep bees myself. Which I was a teen, I was diagnosed with premature rhumatoid arthritis. I hated taking the medicine, and my parents were looking for *anything* that could help. My grandfather (an old-school cowboy - 85 years old and still works the cattle on his ranch personally) swore that bee stings were the best "cure" for arthritis available. My parents got me interested in keeping bees, and I built my own super and even the flats from scrap wood and wire. I found a wild hive in an old abandoned house and was able to commandeer the queen and hive to put in my super. Needless to say, the structure of my comb wasn't anything any professional could use, but it was an awesome project, and to my surprise the be stings DID make the joint pain disappear completely for many years. (When we finally moved, the whole hive was given to a local bee keeper.) I also never had a single allergy growing up, but didn't think to attribute that to the honey.
Now I live in an apartment, and many years later, the joint pain has slowly returned, and for the first time in my life I'm finding out I'm allergic to the local plants. (A blood test, which I didn't know they could do for allergies, says I'm allergic to the local ragweed.) I've been seriously thinking about getting a house, and I figured if I did have a yard I'd like to get back into the bee keeping hobby. I find them fascinating, and even kinda "cute." (Weird for a 33 year old guy to say that, I know.) And there's absolutely nothing in the world like the smell of a beehive. I love it.
The supers and flats are easy enough to make, even moreso with my years of wordworking experience now (an instructable to come maybe?). Beyond that, there are certain things that I think it would just be easier to buy, such as the heating units, and the centrifuges. (Maybe it'd be possible to buy a non motorized one, and attach my own motor? Instructable #2!)
I've looked at the prices online (I actually found the company by looking up the name that was on the centrifuge in your picture) and definitely think it'd be a little on the steep end for a beginner. All that being said, it didn't even dawn on me that bee keepers would have a need to place hives on other people's property! All the perks with none of the hassle!
Thanks for the info! And I love the instructable. Especially the picture of the bee checking out the jar of honey. :)
Jan 2, 2012. 10:08 PMBushie says:
Some correct terminology will help when people are looking for more info':
A "centrifuge" is used for separating honey from the wax cappings before melting the cappings.
An extractor is the proper name for the machine that spins the frames to throw out the honey.
A "honey press" is an old-fashioned means of harvesting honey (which unfortunately also destroys the combs) ~ the advantage of an extracting plant is that the frames can then be re-used immediately (most of the time..).
Jun 22, 2011. 2:11 PMwww.microbike.ie says:
Great Post Go Ahead and move out the flat! they are unhealthy!
Dec 10, 2009. 8:31 PMJonesy Boogieman says:
I loved this instructable!  And the last picture, with the bee investigating the full honey jar, is so cute!  It's like he's putting his own stamp of approval on it! :)
Thanks for your work!
Dec 14, 2009. 8:24 AMJonesy Boogieman says:
I want to try this pretty bad, and even found an instructable for building a honey extractor.  But I have to wait until I can do something in a more rural setting.  My wife is terrified of bees after a couple of bad experiences as a child.
I had thought the workers were all male.  That is so interesting that they're mostly female!  Sort of like an "Amazonian" system :)  My wife might appreciate that!
Aug 29, 2010. 6:22 PMJavin007 says:
Yep, the same goes with ants, too. Ants also are all female with only male "drones" around for mating. While it's true that the worker bees do not lay eggs in a healthy colony, it's not that they *can't* lay eggs. Nature has a rather sick sense of humor here. The queen bee is constantly emitting pheromones. The presence of the queen in the hive is what keeps the female bees from attempting to lay eggs themselves. If a hive loses its queen, the bees will immediately start feeding "royal jelly" to some of the most recently laid eggs in an attempt to raise another queen. (This also happens when the current queen gets too old to effectively do her job.) And this is where it gets weird. When a queen bee is not fertilized by a drone, she will lay "unfertilized" eggs that can only turn into drones. When she is fertilized, then she's capable of laying the female eggs that become the workers (or other queens depending on how they're fed.) The worker bees *are* in fact capable of laying eggs, but are *not* in fact capable of mating with the drones. So if a colony loses its queen for a significant amount of time, sometimes the bees will attempt to "fix" the problem themselves by laying eggs, but in the cruel twist of fate from nature, since they can't mate, all of the eggs they lay will become drones so the hive will ultimately die.
Dec 9, 2009. 1:10 PMcanida says:
This is awesome!  I've always wanted to keep bees, but hosting a hive for an experienced beekeeper sounds like the happy medium, or at least a great way to get started.
Thanks for sharing!
Dec 8, 2009. 2:36 PMlemonie says:
That looks semi-industrial - how many hives have you using this equipment?
What do you do with the wax?
L
Dec 8, 2009. 11:32 PMlemonie says:
Right, I was interested in the size of the beekeeping community?
L
Dec 9, 2009. 11:21 AMlemonie says:
Sounds good - was there much variation in flavours?
L
Dec 9, 2009. 12:49 AMJayefuu says:
Wow fantastic ible. I used to go bee keeping to help my mum's aging friend who found it a struggle to lift the supers full of honey. Was soooooooo interesting.
One thing I'm curious about though, is you mentioned differentiating between the brood cells and honey cells, was that just for interest or did you do that in the honey extracting process? We always had a queen excluder on top of the brood box to stop her laying eggs in the supers above it.
The guy I used to help had 12 hives (that made a LOT of honey) so he had all of this kit himself, but... curiously... NOT the heated knife. We always used to use a palate knife which went back under the grill on a tray after each cut. Your knife you borrow looks much easier!
I think it's great more and more people are starting to keep bees in their back gardens in inner city environments.
Dec 9, 2009. 10:04 AMJayefuu says:
Oooo. Our extractor wasn't heated. Or motorised! Hurray for turning a handle fast! I was fascinated that the bees were clever enough to put their cells on an angle to keep the nectar in. Hence why the frames have to go in a certain way around. I'll definitely get a hive when I finish uni and have more time.
Dec 8, 2009. 9:09 PMcowscankill says:
All I need is a bee hive :D
1-40 of 42next »
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
24
Author:neighborhoodfruit(Neighborhood Fruit)
Neighborhood Fruit helps people find and share fruit locally, both backyard bounty and abundance on public lands. 10,000 trees nationwide and counting! Join us in creating a future where the food we e...
more »
