Honey Lip Gloss
Introduction: Honey Lip Gloss
Hey, get ready to make an easy and awsum lip gloss.
This lip gloss can also be used everyday, even at home because it is also a lip balm. The honey in this gives a yummy taste and honey also has medicinal properties, thus, will nourish the lips.
And you do not even require any beewax.
So, lets not wait anymore and start making this amazing lip gloss :)
Step 1: Materials Required
You will require the following:
  1. Vaseline or any other petroleum jelly
  2. honey
  3. any microwave usable container
  4. eye shadow or an old lipstick of the color you want your lip gloss to be
  5. an empty container in which you will fill your lip gloss
Step 2: Heating the Vaseline
Take 3 teaspoons of vaseline and put it in the microwave usable container. Then heat this in the microwave till the vaseline melts.
Step 3: Adding the Honey
To the melted vaseline add 1 teaspoon of honey and mix them well.
Step 4: Adding Color
To the vaseline and honey mixture add a little eyeshadow or tiny pieces of lipstick and again mix it.
Step 5: Completing the Gloss
Again heat the container in the microwave until the gloss melts completely.
If the vaseline is not able to melting in the microwave, then you can boil some water and keep the container just above the hot water in such a way that the bottom of the container just touches the water, as shown.
Step 6: Filling the Gloss in the Empty Container
Put the melted gloss in the container you choose for it. And then leave it for 5 minutes outside. After 5 minutes when the gloss is semi solid then mix the gloss with a toothpick completely because honey does not completely mix with vaseline, but by mixing now the honey mixes much more than before.
Then refrigerate the gloss till it becomes solid. Once it is solid you can take it out.
Step 7: The Honey Lip Gloss Is Ready :)
Now that your honey lip gloss is ready, use it and look gorgeous. USE IT, FLAUNT IT, ENJOY IT. :)
    • Trash to Treasure
      Trash to Treasure
    • Pro Tips Challenge
      Pro Tips Challenge
    • Science of Cooking
      Science of Cooking
    Love it! this is amazing! thank you so much for this wonderfully simplechapstick!
    I don't have a microwave.. :v
    sorry, its not possible to make this without heat. without heat, the honey, color and vaseline will not mix properly.
    Wow... This is so good. Going to make this one soon :) Thanks for sharing !
    Oo I'm so making this!
